Author Topic: Cant get ULX Admin to work for my dedicated Server!  (Read 7060 times)
JoeV
« on: December 29, 2006, 10:32:54 am »
This is what came up when i put in the things you said to in the access thing
hostname:  Coolguy64's Server w/ ECS!
version : 1.0.0.0/7 2949 secure
udp/ip  :  192.168.0.100:27015
map     :  gm_construct at: 704 x, 132 y, -79 z
players :  1 (8 max)
# userid name uniqueid connected ping loss state adr
#  2 "Coolguy64" STEAM_0:0:9846530 05:17 43 0 active 127.0.0.1:27005
This server is running ULX version 2.900000 from ulyssesmod.net
] lua tprint( ULib.mainUcl )
Unknown command: lua
It works fine in single player, but when i added it to my dedicated server it wouldnt work!
boebi
Re: Cant get ULX Admin to work for my dedicated Server!
« Reply #1 on: January 04, 2007, 08:36:23 am »
You need to add yourself to users.txt, if you play in singleplayer your are admin automatically
Offline spbogie
« Reply #2 on: January 04, 2007, 10:43:37 am »
Which version of Garry's Mod arey you running?
GMod9:
ULX v2.9 was a prot for GM10. Instead download ULib v1.2 and ULX v2.21.
GMod10:
ULX v2.9 is a buggy outdated port. Delete it, and download the latest version of both ULib and ULX from the downloads section. Then add your users to the garrysmod/settings/users.txt file.
« Reply #3 on: January 04, 2007, 10:58:20 am »
He's running GM10.
I still don't know what command to run lua commands directly from console, if there is a way.
Megiddo (or one of us) need to find out and modify the 'troubleshooting access' post in help/support, or at least make it clear that its for old versions.
Megiddo did tell me he's thinking about re-organizing the forums.
Offline spbogie
« Reply #4 on: January 04, 2007, 12:40:03 pm »
Oops should have caught that. The new command is "lua_run".
If you haven't noticed he already did some re-organizing.
« Reply #5 on: January 04, 2007, 02:40:33 pm »
Yes, and the instructions in the sticky on this forum are up to date too. ;)
