Author Topic: Cannot disable Motd  (Read 6159 times)
Offline TheMr
Cannot disable Motd
« on: March 21, 2013, 10:05:10 am »
Hello there I'm having trouble disabling the motd feature on my server. I have deleted the ulx_motd.txt and disabled the part in config file that says
 "ulx showMotd 0; Set to 0 to disable showing motd on connect. Shows the file the cvar motdfile says to. Set to a URL to show a URL.
motdfile ulx_motd.txt ; The motd to show"
anyone got any ideas?
Offline nathan736
Re: Cannot disable Motd
« Reply #1 on: March 21, 2013, 10:10:59 am »
are you sure ulx showmotd is 0 when the server is runing ?
Offline TheMr
« Reply #2 on: March 21, 2013, 10:11:43 am »
Well it's disabled on that config file, unless I need to disable it somewhere else?
Offline nathan736
« Reply #3 on: March 21, 2013, 10:12:35 am »
you never know  ;) the server might be reseting it to 1 for some reason can you check ? or are you not at a computer that can ?
Offline TheMr
« Reply #4 on: March 21, 2013, 10:13:55 am »
I got it hosted on a dedi
Offline nathan736
« Reply #5 on: March 21, 2013, 10:15:02 am »
yeah thats fine but could you run in console  ulx showmotd and see what it gives back for output
Offline TheMr
« Reply #6 on: March 21, 2013, 10:17:54 am »
Getting this
] ulx showmotd
"ulx showmotd" = "1"
 <0/1/(url)> - Shows the motd to clients on startup. Can specify URL here.
  CVAR generated by ULX
Offline nathan736
« Reply #7 on: March 21, 2013, 10:21:38 am »
well its 1 then so you did not turn it off umm did you actualy set ulx showmotd to 0 the non commented one  without ; or -- in frount of it
edit: added out D:
« Last Edit: March 21, 2013, 10:23:39 am by nathan736 »
Offline TheMr
« Reply #8 on: March 21, 2013, 10:25:44 am »
This is what I have changed it to in the config.txt
its set to 0
Offline nathan736
#calling ullysses team >:D
« Reply #9 on: March 21, 2013, 10:43:50 am »
erm cant help you anymore no idea on what is wrong probably something being reset  in the ulx gui
Offline TheMr
« Reply #10 on: March 21, 2013, 10:46:37 am »
Ok well thanks anyway  ;D
« Reply #11 on: March 21, 2013, 01:44:09 pm »
Something's setting it to 1. Check to make sure you don't have another line with "ulx showMotd 1" lower in the config or in other configs in garrysmod/cfg.
« Reply #12 on: March 21, 2013, 02:42:01 pm »
Which cfg did you edit?
If you edited the one in /addons/ulx/data/ulx/config.txt, you didn't follow the directions at the top of that file.
