Author Topic: ULX "!menu" Not Working  (Read 5166 times)
Offline Mr. Pope
« on: March 29, 2013, 02:14:38 pm »
Hey Everyone,
I have a G-Mod server that I intend to turn into a  WWII RP server. And I have ULX installed to moderate with. It worked fine for almost two weeks, but last night (the first time I ran the server with DarkRP) after I restarted it once, ULX stopped working. But the weird thing is when I join the server it still says "Hey 'mr. owner sir' - You're in the 'superadmin' group on this server.", but when I use the "!menu" command, all I see is the regular player version. And when I try to type in the commands manually it says "You do not have access to this command, <My Steam Name>. (I  did delete FAdmin from the DarkRP script, and it still didn't help. ) Any help anyone may have would be appreciated!  :)
-Mr. Pope
Offline Bo98
Re: ULX "!menu" Not Working
« Reply #1 on: March 29, 2013, 02:26:01 pm »
Could be a permissions issue. In the serve console, run
ulx debuginfoThe output will be outputted into a text file (the console prints the location). Paste the output here.
« Reply #2 on: March 29, 2013, 02:27:12 pm »
What bo said is part of the link I give here (he posted while I was writing)
Megiddo said somewhere that Garry broke some file things in a recent update. Not sure if that might be affecting you.
If itn's not Gmod directly, sounds like fadmin or another mod rewrote some of your groups.
Try removing/backing up/or if you want deleting your server gmod/data/ulib/groups.txt and users.txt files (while server is shut down of course).
Then restart server to see if the files are rebuilt, add yourself back to superadmin. Test. Restart again to see if it holds.
If that doesn't work, see /index.php/topic,383.0.html (step 2 onward, but #1 never hurts)
Offline Mr. Pope
« Reply #3 on: March 29, 2013, 03:48:18 pm »
Thank you SO much JamminR! The problem is fixed! I really appreciate it!   :) :D
