Author Topic: ULX Physgun  (Read 27125 times)
ULX Physgun
« on: April 05, 2013, 02:08:35 pm »
I feel that the physgun has become quite outdated so I am aiming to change it, as you can see currently this is very simple and lets admins freeze players like they would props.
-- Last Updated On JUN 21ST, 2015 --
-- I need to recode allot of my old stuff, maybe I'll release a pack someday (#valvetime). --
if CLIENT then return end; if not SERVER then return end
hook.Remove( "PhysgunDrop", "ulxPlayerDrop") -- We don't need this hook since we have a better hook here.
local function isPlayer(ent) return (IsValid(ent) && ent.GetClass && ent:GetClass() == "player") end
local function playerPickup( ply, ent )
local access, tag = ULib.ucl.query( ply, "ulx physgunplayer" )
if isPlayer(ent) and access then
local restrictions = {}
ULib.cmds.PlayerArg.processRestrictions( restrictions, ply, {}, tag and ULib.splitArgs( tag )[ 1 ] )
if restrictions.restrictedTargets == false or (restrictions.restrictedTargets and not table.HasValue( restrictions.restrictedTargets, ent )) then
return false
return true
timer.Simple(0.01, function()
hook.Add("PhysgunPickup", "_ply_physgungrab", function(ply, targ)
if IsValid(ply) and isPlayer(targ) then
if ply:query("ulx physgunplayer") and playerPickup( ply, targ ) then
local allowed = ULib.getUser( "@", true, ply )
if isPlayer(allowed) then
if allowed.frozen && ply:query( "ulx unfreeze" ) then
allowed.phrozen = true;
allowed.frozen = false;
allowed._ulx_physgun = {p=targ:GetPos(), b=true, a=ply}
end, tonumber(HOOK_HIGH)-2); MsgAll('LOADED! 1')
end)
hook.Add("PlayerSpawn", "_ply_physgungrab", function(ply)
timer.Simple(0.001, function()
if IsValid(ply) and ply._ulx_physgun then
local admin = ply._ulx_physgun.a
if ply._ulx_physgun.b and ply._ulx_physgun.p and IsValid(admin) then
ply:SetPos(ply._ulx_physgun.p);
ply:SetMoveType(MOVETYPE_NONE);
if not (IsValid(admin) and admin:KeyDown(IN_ATTACK)) then
ply:SetMoveType( MOVETYPE_WALK )
ply._ulx_physgun = nil
ply:Spawn()
end)
end)
end)
local function physgun_freeze( calling_ply, target_ply, should_unfreeze )
local v = target_ply
if v:InVehicle() then
v:ExitVehicle()
if not should_unfreeze then
v:Lock()
v.frozen = true
v.phrozen = true
ulx.setExclusive( v, "frozen" )
v:UnLock()
v.frozen = nil
v.phrozen = nil
ulx.clearExclusive( v )
v:DisallowSpawning( not should_unfreeze )
ulx.setNoDie( v, not should_unfreeze )
if v.whipped then
v.whipcount = v.whipamt -- Will make it remove
hook.Add("OnPhysgunFreeze", "_ulx_physgunfreeze", function(pl, ent)
if isPlayer(ent) then
ent:SetMoveType( MOVETYPE_WALK )
ent._ulx_physgun = nil
end)
hook.Add("PhysgunDrop", "_ulx_physgunfreeze", function(pl, ent)
if IsValid(pl) and isPlayer(ent) then
if pl:query("ulx freeze") then
local isFrozen = ( ent:IsFrozen() or ent.frozen or ent.phrozen );
ent:SetMoveType(pl:KeyDown(IN_ATTACK2) and MOVETYPE_NONE or MOVETYPE_WALK);
if pl:KeyDown(IN_ATTACK2) and not isFrozen then
if pl:query( "ulx freeze" ) then
ent:SetVelocity(ent:GetVelocity()*-1);
ulx.freeze( pl, {ent}, false );
if ent.frozen then ent.phrozen = true end;
elseif pl:query( "ulx unfreeze" ) and isFrozen then
if pl:KeyDown(IN_ATTACK2) and pl:query( "ulx freeze" ) then
physgun_freeze(pl, ent, true)
timer.Simple(0.001, function() physgun_freeze(pl, ent, false) end);
ulx.freeze( pl, {ent}, true );
if not ent.frozen then ent.phrozen = nil end;
end);
end); MsgAll('LOADED! 2')
end)
How to install: Put it in "lua/autorun/" make sure that its a ".lua" file.
Current Error: Players can still kill them selves while being held.
I plan this to be expanded with new and innovative ideas, if you have an idea but don't know how to code feel free to post any way because I am sure that some one who does know how to code may pick it up.
(This is not a release because it is not done yet. I will make a release post when its done or close to being done.)
(This does work tho.)
P.S: A big thanks to CapsAdmin and Python1320. (You see I got the idea from QBox.)
« Last Edit: June 10, 2017, 08:43:27 pm by LuaTenshi »
Offline Joram
Re: ULX Physgun
« Reply #1 on: August 14, 2014, 10:46:24 am »
Excuse me if I am grave digging here but is there a way to add a usergroup and command to it?
Offline ChaosWolf
Re: ULX Physgun
« Reply #2 on: August 21, 2014, 05:32:13 pm »
if your just wanting to allow a group only to use the weapon you want to add.
  1. ITEM.AllowedUserGroups = { "superadmin", "admin", "donator", "etc" }
easy enough, just put it below the rest of your ITEM codes and your good to go, takes affect the next map change
Offline Joram
Re: ULX Physgun
« Reply #3 on: August 29, 2014, 04:10:43 am »
No I ment a rank to freeze a player, Like moderators can pickup but not freeze
Offline ChaosWolf
Re: ULX Physgun
« Reply #4 on: August 29, 2014, 10:26:28 am »
I don't see why you couldn't use the freeze command then pick them up. As for freezing in mid air like a prop. I don't know.
Offline Joram
Re: ULX Physgun
« Reply #5 on: August 31, 2014, 12:18:32 pm »
Because we are using it now it's really usefull for grabbing a minge quickly and freeze them, But I would like to restrict ranks to it
Offline Neku
Re: ULX Physgun
« Reply #6 on: August 31, 2014, 02:23:16 pm »
bind b "ulx freeze @"
That'll freeze whoever you're looking at.
Offline Joram
Re: ULX Physgun
« Reply #7 on: September 09, 2014, 06:59:15 am »
Waw didn't know about that one!
But I modified it (It's alot for me)
it's probally shitty but people may be worse then me so:
function FGod( ply, dmginfo )
if(ply:GetNetworkedVar("FGod") == 1) then
dmginfo:ScaleDamage( 0 )
hook.Add("EntityTakeDamage", "FGod", FGod)
hook.Add("PhysgunDrop", "ply_physgunfreeze", function(pl, ent)
hook.Remove( "PhysgunDrop", "ulxPlayerDrop" ) --This hook from ULX seems to break this script that's why we are removing it here.
ent._physgunned = false
if( ent:IsPlayer() && ( pl:IsUserGroup( "YourAdminGroupHere" ) or pl:IsUserGroup( "YourSecondAdminGroupHere" )) ) then     --If you want to insert another one insert "or pl:IsUserGroup( "YetAnotherGroup" )"
-- predicted?
if(pl:KeyDown(IN_ATTACK2)) then
ent:Freeze(true)
ent:SetNetworkedVar("FGod", 1)
ent:SetMoveType(MOVETYPE_NOCLIP)
ent:Freeze(false)
ent:SetNetworkedVar("FGod", 0)
ent:SetMoveType(MOVETYPE_WALK)
if SERVER then
-- NO UUUU FKR
if !ent:Alive() then
ent:Spawn()
self:PlayerSpawn(ent)
ent:SetPos(pl:GetEyeTrace().HitPos)
else -- If it wasn't an admin in your defined groups then don't do anything
ent:Freeze(false)
return --self.BaseClass:PhysgunDrop( pl , ent )
end)
hook.Add( "PhysgunPickup", "ply_physgunned", function(pl, ent)
ent._physgunned = true
end)
function playerDies( pl, weapon, killer )
if(pl._physgunned) then
return false
return true
hook.Add( "CanPlayerSuicide", "playerNoDeath", playerDies )
Offline 007section1
Re: ULX Physgun
« Reply #8 on: November 08, 2014, 08:24:11 am »
which lua file folder should i do it in ive tried the gmod lua then the gmod ulib how do i do it im really stuck
Re: ULX Physgun
« Reply #9 on: March 29, 2015, 09:08:25 pm »
I have updated the code above, it should now work for everyone. Without even having to remove the hooks from ULX!
Offline Livaco
    • Livaco
Re: ULX Physgun
« Reply #10 on: April 02, 2015, 12:47:05 am »
Good Idea Because People Woint Jump Down From Admin Sits And If Theirs None There Just Freeze Them Up Into The Air!
My Website
My Addons
PermaBanV1.0
Livaco Products©
