Author Topic: Freetime D:  (Read 5528 times)
Offline Mindless
Freetime D:
« on: April 06, 2013, 09:19:29 am »
Can anyone update this for Garrys Mod 13? The workshop one is broken or doesn't exists anymore.
http://www.garrysmod.org/downloads/?a=view&id=130148
Re: Freetime D:
« Reply #1 on: April 06, 2013, 11:31:37 am »
I am not really good at GUI stuff, but I will take a look at it.
For now you can try using the scoreboard from FAdmin without having FAdmin, what you do is remove every thing in FAdmin accept the "cl_interface" folder.
Also I am not sure if the above suggestion would work but it is worth a try.
UPDATE: I just modified the scoreboard from aowl... https://dl.dropbox.com/u/10896585/scoreboard.lua
It did not work in my tests, but then again my version of DarkRP is completely broken... so may be you will have more luck then me.
« Last Edit: April 06, 2013, 01:57:42 pm by HeLLFox_15 »
Offline Mindless
Re: Freetime D:
« Reply #2 on: April 06, 2013, 01:59:17 pm »
Thanks HellFox, I got it fixed!
Re: Freetime D:
« Reply #3 on: April 06, 2013, 02:03:04 pm »
No problem, mind updating your server IP so that I can check it out? (The one on your site and the one in your advert here seem to lead to a different server.)
Offline Mindless
Re: Freetime D:
« Reply #4 on: April 06, 2013, 02:58:14 pm »
Yeah, just busy in development opening my roleplay server again, i'll update it shortly.
