Poll
Was this module useful, and helpful?
Yes :)
135 (93.8%)
No :(
9 (6.3%)
Total Members Voted: 0
Author Topic: Utime Hour Changer Addon :) [2.18v]  (Read 154213 times)
Re: Utime Hour Changer Addon :)
« Reply #15 on: December 15, 2013, 05:55:21 pm »
Orilla, Utime, and this addon to adjust times in it, has nothing to do with player access.
5 hours, or a 1000, UTime will only show how many.
If you are using another addon that adjusts permission based on time played, it's possible it has its own tracking.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #16 on: December 15, 2013, 07:41:10 pm »
Hi Guys
I used this on single player, and set myself down to the equivelant of user. I could still use this command though, even though I wasnt a super admin. Do you know why this is?
THanks
-Orrila
I'll check the addon later, but if something is broken with permissions it shouldn't be related to my addon. My addon doesn't even have permission control except for when you set access to players for the use of this addon. I'll check it anyways...
Basically is my answer anyways \/
Offline orrila
« Reply #17 on: December 15, 2013, 11:48:47 pm »
Hi again
Sorry, I just think it is related to your addon. It may not be - your the coder and all so you know, but;
It was only the allow change time command in Apple's Creations tab that I uncheck for user, but checked for superadmin.
All the other commands I could not use.
I then, when set to not-superadmin was able to use this command.
But hey, this was in single player and that couldve been the issue. So I will check on a listen server soon, and when I have a new pc in about a months time, I can run a local server and run via that to check to.
THanks
-Orrila
« Reply #18 on: December 16, 2013, 02:50:23 am »
Thank you for your concern. I've looked into this though, and there were no issues that were detected, and that were somewhat similar to your issues. So as far as I know, this addon still remains to not have any issues. I had a few people test it on their server, and it all works fine as dandy. I hope you get your issue fixed.
Offline orrila
« Reply #19 on: December 16, 2013, 05:49:05 am »
Well, thanks.
Its prob the fact im on single player that is why its not working. I'll test in multiplayer sometime. Thanks a million though for the help.
-Orrila
Offline DendeSon
  • No.
    • Gentlemen Gaming
« Reply #20 on: December 23, 2013, 02:51:16 pm »
Any way to view a players time using this if the player is not on the server?
« Reply #21 on: December 23, 2013, 05:03:38 pm »
Nope, sorry. That would be impossible.
Offline orrila
« Reply #22 on: December 24, 2013, 12:24:57 am »
Not with this, but certainly with some changes to Utime, or looking in logs or something.
Offline Chironex
  • Formerly known as Kyzer
« Reply #23 on: March 18, 2014, 11:39:36 pm »
I did exactly the same thing as this addon few days ago...
Anyway, I looked your script and didn't understand why you made it so complex. Here is mine:
if file.Exists("autorun/cl_utime.lua", "LUA") then
function ulx.sethours( calling_ply, target_plys, hours )
for i=1, #target_plys do
local v = target_plys[ i ]
local removeSessionTime = true
if ( hours < 0 ) then
hours = math.max( ( v:GetUTime() / 3600 ) + hours, 0 )
removeSessionTime = false
local time = (hours * 3600)
if ( removeSessionTime ) then
time = time - (time % 3600) - v:GetUTimeSessionTime()
v:SetUTime( time )
ulx.fancyLogAdmin( calling_ply, "#A set #T's hours to #i", target_plys, hours )
local sethours = ulx.command( "User Management", "ulx sethours", ulx.sethours, "!sethours" )
sethours:addParam{ type=ULib.cmds.PlayersArg }
sethours:addParam{ type=ULib.cmds.NumArg, min = -10000, max = 10000, default = 0, hint = "hours", ULib.cmds.optional, ULib.cmds.round }
sethours:defaultAccess( ULib.ACCESS_ADMIN )
sethours:help( "Sets target(s)'s UTime hours." )
Negative value will remove hours ;)
« Last Edit: April 28, 2014, 01:27:34 pm by Chironex »
« Reply #24 on: April 05, 2014, 03:17:06 pm »
if ( file.Exists("autorun/cl_utime.lua", "LUA") ) then
for ( i = 1, #target_plys ) do
local target_ply = target_plys[ i ]
hours = math.max( ( target_ply:GetUTime() / 3600 ) + hours, 0 )
target_ply:SetUTime( hours * 3600 )
sethours:addParam{ type = ULib.cmds.PlayersArg }
sethours:addParam{ type = ULib.cmds.NumArg, min = -10000, max = 10000, default = 0, hint = "hours", ULib.cmds.optional, ULib.cmds.round }
I made mine special for a mysql utime, and I just never removed the other code, as it didn't really affect the people who were using mysql lite servers
Offline jadon999
« Reply #25 on: May 24, 2014, 08:26:54 am »
Hey Chaos! This addon looks great but when i try to install it it doesnt work,
Methods ive tried to install,
Ive put the whole folder inside my addons folder(didnt think it would work) then
I put the lua inside the lua/ulx/modules/sh.
After i did both ways i try to go and give permission to a rank your name "Apples Creations" Doesnt Not pop up on groups perm.
I also restarted it and nothing happend. i Have ulx.3.61 and ulib 2.51
Any help please!
-Thanks
« Reply #26 on: May 31, 2014, 10:36:07 am »
Any help please!
-Thanks
I'm sorry, but I really don't understand what the issue is. All this mod changed the players utime, but I think you're getting confused on what this mod does, or with something else.
Offline Valgoid
  • Wanna Be Lua King
« Reply #27 on: June 11, 2014, 09:11:54 am »
I used this but everytime I would restart the server it would lose the time that I had set and go back to the original. Anyway to fix that?
« Reply #28 on: June 17, 2014, 07:24:40 am »
Are you using mysql utime, and if you are then ummm ye. If you are not, are you using the official utime?
Offline Navarone
« Reply #29 on: July 22, 2014, 04:33:18 am »
Is there a console command, or do I have to actually be on the server to use it?
