Author Topic: no targets found  (Read 8421 times)
Offline bender180
    • Benders Villa
no targets found
« on: April 13, 2013, 09:51:25 am »
With my custom commands when i use them in single player through xgui i receive the error "argument #1: no targets found" however when i run the command through the console in single player it works perfectly. On multiplayer servers the commands work great from xgui or console, is this a bug in my code or is this an xgui bug?
Re: no targets found
« Reply #1 on: April 13, 2013, 12:09:40 pm »
Sounds like something with xgui. Are you targeting yourself or a bot. before the error, what does xgui try to run?
Offline bender180
    • Benders Villa
« Reply #2 on: April 13, 2013, 12:19:31 pm »
Happens when i target myself. I haven't tried on a bot because you cant spawn one in a single player game. The commands work fine from xgui when the min players is 2 or more.
Offline bender180
    • Benders Villa
« Reply #3 on: April 14, 2013, 08:12:54 pm »
anyone have any idea how i can fix this?
Offline nathan736
« Reply #4 on: April 15, 2013, 08:26:38 am »
could you post the code u used ?  :-\
« Reply #5 on: April 16, 2013, 07:42:12 am »
Are you able to use any other commands from XGUI?
Offline bender180
    • Benders Villa
« Reply #6 on: April 16, 2013, 04:16:53 pm »
Turns out none of the commands work from xgui they are returning "Command "ulx slay", argument #1: no targets found" and something else i noticed was in psay my name doesn't appear (intentional?), but again all the commands work from console
« Reply #7 on: April 16, 2013, 05:46:16 pm »
Yes, your name not appearing in psay is intentional. We don't officially support ULX/XGUI in single player, but we'll check into the issue and see what we can find.
« Reply #8 on: April 16, 2013, 07:15:34 pm »
Bender, before we go digging too deep, have you modified any of our default code or functions?
Even directly, or through your own addon/command work?
Offline bender180
    • Benders Villa
« Reply #9 on: April 17, 2013, 08:55:51 am »
I don't think I have, I used the commands you ship it with to build my commands so there is a possibility I did it with out realizing I'll try removing my commands to see if it makes a difference.
« Reply #10 on: April 17, 2013, 02:06:14 pm »
I doubt you did. You'd have to have actually written commands over-writing ULib functions.
But I wanted to check first.
