Author Topic: gmod13- ULX Problem  (Read 4399 times)
Offline Schiaffino
gmod13- ULX Problem
« on: April 13, 2013, 09:19:52 pm »
Hello guys, i download ulx and install it on my gmod server, the problem? i setup everything but when i restart the server, everything deleted ... what can i do ? its weird, i set the max amount of props for example, then restart, and turn back to the normal max amount of props.
Thanks,
Re: gmod13- ULX Problem
« Reply #1 on: April 13, 2013, 09:34:21 pm »
It's quite obvious.
Picture worth (not 1000) words.
You'll need to google how to use server.cfg (not a ULX file, source/gmod)
Click to enlarge and read the image.
Offline Schiaffino
« Reply #2 on: April 13, 2013, 09:48:16 pm »
oh gotcha :), thanks, btw how i can create the adverts?, because i create one then restart and dissapear hehe
« Reply #3 on: April 13, 2013, 10:32:11 pm »
Probably due to Garry's broken file i/o issue right now.
If you don't have a gmod/data/ulx/adverts.txt already, after shutting down server, copy gmod/addons/ulx/data/ulx/adverts.txt to gmod/data/ulx.
Restart server. Then try editing.
If that doesn't work, you'll most likely have to wait until 1) Garry fixes file i/o or 2) We write our own wrapper.
Megiddo has mentioned bad gmod file i/o in other threads and at the github issue tracker
« Reply #4 on: April 14, 2013, 01:26:09 pm »
Adverts should save now.
