Author Topic: Chat Problems  (Read 4879 times)
Offline cortez (Mr. T. FOO!)
Chat Problems
« on: April 19, 2013, 02:12:44 pm »
I run a TTT server with ULX admin mod and recently added a mapvoting pluggin available through the steam workshop. After adding it dead players could send alive messages by using the console and the ulx mute command (which is vanilla) stopped working. I've reviewed the code several times and cannot figure out what is causing the problem. Any help is appreciated.
--Amount of players who have to request a vote, 1=all, 0.5=half of everyone
local votereqperc= 0.5
--Voting time
local votetime   = 30
--Checks if gamemode is terrortown
if GetConVarString("gamemode") == "terrortown" then
--Server side
if SERVER then
local votestarted = false
local voteoverride = false
local votestartrequests={}
local currentvotes={}
local playerlist={}
util.AddNetworkString("serverWantsAVote")
util.AddNetworkString("userChangedVote")
util.AddNetworkString("broadcastUserVoteChange")
util.AddNetworkString("thePoolIsClosedAndSoIsVoting")
util.AddNetworkString("playerWantsToStartVote")
print("This is a test mod and has been loaded on the servear")
RunConsoleCommand("mapcyclefile", "data/mapscyclething.txt")
if file.Exists("mapcyclething.txt", "DATA") != false then
file.Delete("mapcyclething.txt")
local maplist={}
for k,v  in pairs(file.Find("maps/*.bsp", "GAME") ) do
local lowercasename = string.lower(v)
if (string.find(lowercasename, "^cs_") or string.find(lowercasename, "^de_") or string.find(lowercasename, "^ttt_") or string.find(lowercasename, "^dm_")) then
local mat = nil
local Category = "Other"
local name= string.gsub(v, ".bsp", "")
mat="../maps/"..name..".png"
resource.AddFile(mat)
maplist[v]={Material = mat, Name = name}
for k,v in pairs(maplist) do
file.Append("mapcyclething.txt", v.Name.."\n")
local maps = string.Explode("\n",file.Read("mapcyclething.txt","DATA"))
table.remove(maps)
if not table.HasValue(maps,game.GetMap()) then
table.insert(maps, 1, game.GetMap())
local curmap=table.remove(maps,table.KeyFromValue(maps, game.GetMap()))
table.insert(maps, curmap)
file.Write("mapcyclething.txt","")
for k,v in pairs(maps) do
file.Append("mapcyclething.txt", v.."\n")
net.Receive("userChangedVote",function(len, ply)
local mapID=net.ReadInt(16)
playerlist[ply:UniqueID()]=mapID
net.Start("broadcastUserVoteChange")
net.WriteInt(mapID,16)
net.WriteString(ply:UniqueID())
net.Broadcast()
end)
function votingEnded()
for k,v in pairs(playerlist) do
currentvotes[v]=currentvotes[v]+1
local currmap=1
local maxvotes=0
for i=1,table.Count(maps) do
if currentvotes[i]>maxvotes then
maxvotes=currentvotes[i]
currmap=i
print("Winning map is "..maps[currmap])
for _, v in pairs(player.GetAll()) do
v:ChatPrint( "Winning map is "..maps[currmap].."! Switching to it in a few seconds." )
timer.Simple(5,function() RunConsoleCommand("changelevel", maps[currmap]) end)
net.Start("thePoolIsClosedAndSoIsVoting")
net.Broadcast()
votestarted=false
--hook.Add("TTTBeginRound", "roundReallyStart", votingEnded)
local voteover=false
function startVoteMaybe()
local maxtime = GetConVarNumber("ttt_roundtime_minutes") or 10
if (GetConVarNumber("ttt_haste") or 0) == 1 then
maxtime = (GetConVarNumber("ttt_haste_starting_minutes") or 5) + table.Count(player.GetAll())*(GetConVarNumber("ttt_haste_minutes_per_death") or 0.5)
maxtime = maxtime + GetConVarNumber("ttt_preptime_seconds") + GetConVarNumber("ttt_posttime_seconds")
if GetGlobalInt("ttt_rounds_left", 6) == 1 or math.floor(((GetGlobalInt("ttt_time_limit_minutes") or 60)*60 - CurTime())/60) <= maxtime or voteoverride then
if voteover == false then
print("Sending vote request")
votestarted=true
net.Start("serverWantsAVote")
currentvotes[i]=0
net.WriteTable(maps)
net.Broadcast()
timer.Simple(votetime, function() votingEnded() end )
voteover=true
return true
return false
-- hook.Add( "TTTPrepareRound", "roundStartThingy",startVoteMaybe)
hook.Add( "TTTDelayRoundStartForVote", "roundStartThingy",startVoteMaybe)
function voterequested(ply,strText,plyalive)
if string.Explode(" ", strText)[1] == "!rtv" then
if voteoverride == false then
if votestartrequests[ply:UniqueID()] == 1 then
return ""
votestartrequests[ply:UniqueID()] = 1
local playercount=table.Count(player:GetAll())
playercount=math.floor(playercount*votereqperc)
if playercount < 1 then
playercount = 1
local votes=0
for k,v in pairs(player:GetAll()) do
if votestartrequests[v:UniqueID()] == 1 then
votes=votes+1
if votes >= playercount then
voteoverride=true
net.Start("playerWantsToStartVote")
net.WriteString(ply:GetName())
net.WriteInt(playercount,16)
net.WriteInt(votes,16)
net.Broadcast()
return ""
return strText
hook.Add("PlayerSay", "startvotemaybe", voterequested)
--Client Side
if CLIENT then
util.PrecacheSound("UI/buttonclick.wav")
local cl_mapvote = nil
local votebuttons = {}
local avatars = {}
local playerlists = {}
local currentvotes= {}
local oldvotes   = {}
local playerVelX={}
local playerVelY={}
local playerPosX={}
local playerPosY={}
local listopened=false
local btnW=400
local btnH=20
local spacing=3
--Update loop
function thinking()
if cl_mapvote != nil and listopened then
gui.EnableScreenClicker(true)
cl_mapvote:MoveToFront()
for k,v in pairs(player.GetAll()) do
local id = v:UniqueID()
if avatars[id] != nil and currentvotes[id]!=0 then
local position = 1
for k,v in pairs(playerlists[currentvotes[id]]) do
if v == id then
position = k
local x = playerPosX[id]
local y = playerPosY[id]
local vx = playerVelX[id]
local vy = playerVelY[id]
local x2,y2 = votebuttons[currentvotes[id]]:GetPos()
x2 = x2+btnW-(btnH*(position))
local speed = 0.01
local dx = (x2-x)
local dy = (y2-y)
local dist = math.sqrt(dx*dx + dy*dy)
if dist > 0 then
dx=dx/dist
dy=dy/dist
vx= (vx+dx)*0.98
vy= (vy+dy)*0.98
if dist < 0.8 then
vx= vx*0.1
vy= vy*0.1
local vdist= math.sqrt(vx*vx + vy*vy)
if vdist < 1 then
vx = 0
vy = 0
x=x2
y=y2
--[[if math.abs(dx) <= 1.0 then
x=x2
if math.abs(dy) <= 1.0 then
y=y2
x = x + vx
y = y + vy
playerPosX[id] = x
playerPosY[id] = y
playerVelX[id] = vx
playerVelY[id] = vy
avatars[id]:SetPos(x,y)
hook.Add("Think", "updateloop", thinking)
--Will display how many votes there are for starting a vote and stuff.
net.Receive("playerWantsToStartVote",  function()
local votename=net.ReadString()
local playercount=net.ReadInt(16)
local votecount=net.ReadInt(16)
if votecount < playercount then
chat.AddText(
Color(100,244,0,255),
votename,
" wants to start a map vote! Type say !rtv if you too want to vote.\n",
Color(100,200,0,255),
"Votes: "..votecount.."/"..playercount
chat.AddText(
Color(0,255,0,255),
votename.." voted, and filled the voting quota!\nMap vote will begin at the end of this round, yep."
surface.PlaySound("UI/buttonclick.wav")
chat.PlaySound()
end)
--When a user has changed what map they want
net.Receive("broadcastUserVoteChange", function()
if listopened then
local map=net.ReadInt(16)
local user=net.ReadString()
if currentvotes[user] != map then
if currentvotes[user] != nil and currentvotes[user] != 0 then
local position = 1
for k,v in pairs(playerlists[currentvotes[user]]) do
if v == id then
position = k
table.remove(playerlists[currentvotes[user]],position)
table.insert(playerlists[map], user)
--oldvotes[user]=currentvotes[user]
currentvotes[user]=map
end)
--Closes the voting window
function closeVotingWindow()
listopened=false
cl_mapvote:AlphaTo(0,0.5,0)
timer.Simple(0.5,function()
cl_mapvote:Remove()
cl_mapvote=nil
gui.EnableScreenClicker(false)
end)
net.Receive("thePoolIsClosedAndSoIsVoting", function()
closeVotingWindow()
end)
net.Receive("serverWantsAVote",function()
if listopened then
return false
listopened=true
avatars={}
playerlists={}
cl_mapvote = vgui.Create("DPanel")
cl_mapvote:SetWide(cl_mapvote:GetParent():GetWide())
cl_mapvote:SetTall(cl_mapvote:GetParent():GetTall())
cl_mapvote:Center()
cl_mapvote:SetAlpha(0)
cl_mapvote:AlphaTo(255,1,0)
cl_mapvote.Paint = function()
surface.SetDrawColor(100,100,100,200)
if cl_mapvote != nil then
surface.DrawRect(0,0,cl_mapvote:GetWide(), cl_mapvote:GetTall())
cl_mapvote.label = vgui.Create("DLabel",cl_mapvote)
cl_mapvote.label:SetPos(20,20)
cl_mapvote.label:SetText("Vote for the next map")
cl_mapvote.label:SizeToContents()
cl_mapvote.label:SetColor(Color(255,0,0,255))
-- List for people who haven't voted
local unvotedPlayers=vgui.Create("DPanelList", cl_mapvote)
unvotedPlayers:SetSize(btnH,cl_mapvote:GetTall()-20)
unvotedPlayers:SetPos(10,10)
local x = math.random()*300
local y = math.random()*600
local playerIcon=vgui.Create("AvatarImage",cl_mapvote)
playerIcon:SetSize(btnH,btnH)
playerIcon:SetPlayer(v,32)
avatars[v:UniqueID()]=playerIcon
local id=v:UniqueID()
playerVelX[id]=0
playerVelY[id]=0
playerPosX[id]=x
playerPosY[id]=y
playerIcon:SetPos(x,y)
currentvotes[v:UniqueID()]=0
-- unvotedPlayers:AddItem(playerIcon)
local maps=net.ReadTable()
for i = 1,table.Count(maps) do
local btnoverlay = vgui.Create("DButton", cl_mapvote)
btnoverlay.Paint= function()
local btn = vgui.Create("DPanel",cl_mapvote)
btn.Paint = function()
local x,y= btn:GetPos()
--surface.SetDrawColor
draw.RoundedBox(4,0,0,btn:GetWide(),btn:GetTall(),Color(88,106,255,255))
btnoverlay:Center();
btnoverlay:AlignTop(math.floor((i-1)*0.5)*(btnH+spacing)+btnH)
btnoverlay:AlignLeft(cl_mapvote:GetWide()*0.5+ ((i+1)%2-1)*(btnW+spacing))
btn:AlignTop(math.floor((i-1)*0.5)*(btnH+spacing)+btnH)
            btn:AlignLeft(cl_mapvote:GetWide()*0.5+ ((i+1)%2-1)*(btnW+spacing))
btnoverlay:SetText("")
btn.mapName=maps[i]
btn.label=vgui.Create("DLabel", btn);
btn.label:SetText(maps[i])
btn.label:SizeToContents()
btn.label:SetColor(Color(255,242,237,255))
btn.label:Center();
btn.label:AlignLeft(10)
btnoverlay:SetSize(btnW,btnH)
btn:SetSize(btnW,btnH)
btn:MoveToBack()
btnoverlay:MoveToFront()
votebuttons[i]=btn
btnoverlay.DoClick = function()
net.Start("userChangedVote")
net.WriteInt(i,16)
net.SendToServer()
playerlists[i]={}
local closebtn= vgui.Create("DButton", cl_mapvote)
closebtn:SetWide((btnW+spacing)*2)
closebtn:Center()
closebtn:AlignBottom(20)
closebtn:SetText("Close Window. Skip vote, whatever, I'm done here.")
closebtn.DoClick = function()
closeVotingWindow()
end )
Re: Chat Problems
« Reply #1 on: April 19, 2013, 03:26:18 pm »
This addon was made by a programmer who is unfamiliar with how hooks work in Garry's Mod. Remove the "return strText" in the PlayerSay hook. It should fix both problems.
Re: Chat Problems
« Reply #2 on: April 19, 2013, 04:09:52 pm »
Thank you very much for your assistance, this fixed the issue. Sorry for not posting this in the right place. Locking the thread.
