Author Topic: Setting up ULX on dark rp  (Read 8889 times)
Re: Setting up ULX on dark rp
« Reply #15 on: April 21, 2013, 05:48:02 pm »
Then don't run two admin mods.
We wrote ULX for most commands, not all, but most, to work in any gamemode.
If another gamemode author wrote an admin mod for their gamemode, why use ULX?
Please don't expect us to fix it other than say 'disable it to make sure our commands work'
« Reply #16 on: April 21, 2013, 08:53:02 pm »
When will people learn or accept that ULX does NOT work with FAdmin. The author of FAdmin did NOT write it to be compatible with other admin mods. The only fix is to remove FAdmin. Plenty of DarkRP servers do this if they prefer ULX. There are some ULX extensions to add some DarkRP functionality that you lose by removing FAdmin if you look in the releases section.
Also, ProTip: There is an edit button. You don't need to post 7 posts in a row to add more information to your thread.
