Author Topic: Ulx New Commands  (Read 9248 times)
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Ulx New Commands
« on: April 22, 2013, 07:07:19 pm »
Is it possible to add like a text when creating a custom ulx plugin?
An example is like this:
local setmodel = ulx.command( CATEGORY_NAME, "ulx setmodel", ulx.setmodel, "!setmodel" )
setmodel:addParam{ type=ULib.cmds.PlayerArg }
setmodel:addParam{ type=ULib.cmds.StringArg, hint="models/headcrabblack.mdl" }
setmodel:addParam{ type=ULib.cmds.NumArg, min=0, max=255, default=255, hint="Red", ULib.cmds.round, ULib.cmds.optional }
setmodel:addParam{ type=ULib.cmds.NumArg, min=0, max=255, default=255, hint="Green", ULib.cmds.round, ULib.cmds.optional }
setmodel:addParam{ type=ULib.cmds.NumArg, min=0, max=255, default=255, hint="Blue", ULib.cmds.round, ULib.cmds.optional }
setmodel:defaultAccess( ULib.ACCESS_ADMIN )
setmodel:help( "Set any model to a player - !setmodel" )
So would there be a way to add text saying like w/e, instead of using "Help"
Re: Ulx New Commands
« Reply #1 on: April 22, 2013, 07:30:56 pm »
You lost me.
Please define/explain 'add text' in another way.
Where are you wanting this text to appear?
What context?
« Reply #2 on: April 23, 2013, 11:57:25 am »
I am also confused.
Offline nathan736
« Reply #3 on: April 24, 2013, 08:27:59 am »
what he PROBABLY means is he wants to use a non-standard text when ulx prints something in the chat?
OR
he .. idk. his copy paste confuzles me
« Last Edit: April 24, 2013, 08:37:55 am by nathan736 »
« Reply #4 on: May 13, 2013, 08:38:08 am »
Well seeing as how I said it the first time I "might of" confused some people so let explain it like this. Well you know when you type just "!hp" and it will show you an example of its use :help('EXAMPLE HERE'). Now here is my problem, in xgui you will also see the example for whatever command you are using. What I want is to have like just text that will only show for that command in xgui. Like a text saying what I want it to say only showing in xgui and not in the Helpt text.
« Reply #5 on: May 13, 2013, 07:24:46 pm »
Not as separate as you want, no.
The 'Hint' parts of each parameter will show even if you don't use the :help parameter, but, that's not exactly what you're wanting.
Why are you not wanting commands in help but in XGUI?
« Reply #6 on: May 14, 2013, 07:04:12 pm »
I want it because I'm going to make it so the Version number of some of the tools sooner or later.
