Author Topic: Color Vector error?  (Read 7456 times)
Offline Phoenix_8754
Color Vector error?
« on: May 10, 2013, 07:57:21 am »
My friend and I were on my server when I changed to a different class it said too many LUA errors! So I removed the class started up again and switched to the mayor class everyting is fine until I get shot and die, once again LUA errors! At this point I check the log and it says Color Vecctor error! Then some lines of what I imagine to be colors...... my friend was on by himself building a wwire creation and once he added the advanced wire tools and used it e got kicked for lua errors! Still the color vector....... Does anyone know what's happening and what I should do? Oh, and I'm not sure if this helps or not but the errors did not start happening until I built a "death machine" with a few turrets in wire...
        -Phoenix
Ill try to not annoy you with my many questions. ;)
Re: Color Vector error?
« Reply #1 on: May 10, 2013, 10:14:03 am »
If you share the full error with us we may be able to of some help, but otherwise we would just be speculating wildly.
« Reply #2 on: May 10, 2013, 02:38:19 pm »
Something you can do in the meantime..
sv_kickerrornum 0
This will tell the server not to kick clients for errors.
« Reply #3 on: May 10, 2013, 02:40:50 pm »
sv_kickerrornum 0
Oh! Very helpful! But as odd as this may sound it fixed itself. :D
« Reply #4 on: May 10, 2013, 03:13:15 pm »
I doubt that.. likely you just haven't encountered it again yet.
« Reply #5 on: May 12, 2013, 01:28:47 pm »
Its an error that slipped by Garry should be fixed in the next update or so... (You normally see it while playing DarkRP)
