Author Topic: String arg  (Read 7461 times)
Offline bender180
    • Benders Villa
String arg
« on: May 10, 2013, 08:53:50 am »
I'm still relatively new to lua, and I've been trying to use ULib.cmds.StringArg but I'm having some trouble getting the data from the string to be passed into the command. I made a table for the completes argument and its appearing in game but i cant get the data from the string to work with my command. Whats the easiest way to get the data from the string into the command?
------------------------------ Force --------------------------------
ulx.role = {}
local function updateRoles()
table.Empty( ulx.role ) -- Don't reassign so we don't lose our refs
    table.insert(ulx.role,"traitor") -- Add "traitor" to the table.
    table.insert(ulx.role,"detective") -- Add "detective" to the table.
    table.insert(ulx.role,"innocent") -- Add "innocent" to the table.
hook.Add( ULib.HOOK_UCLCHANGED, "ULXRoleNamesUpdate", updateRoles )
updateRoles() -- Init
function ulx.force( calling_ply, target_plys, role )
    if role == "traitor" then role == ROLE_TRAITOR end
    if role == "detective" then role == ROLE_DETECTIVE end
    if role == "innocent" then role == ROLE_INNOCENT end
   for i=1, #target_plys do
local v = target_plys[ i ]
                      v:SetRole(role)
    SendFullStateUpdate()
    ulx.fancyLogAdmin( calling_ply, true, "#A set #T to #s", target_plys, role )
local force = ulx.command( CATEGORY_NAME, "ulx force", ulx.force )
force:addParam{ type=ULib.cmds.PlayerArg }
force:addParam{ type=ULib.cmds.StringArg, completes=ulx.role, hint="Role", error="invalid role \"%s\" specified", ULib.cmds.restrictToCompletes }
force:defaultAccess( ULib.ACCESS_SUPERADMIN )
force:help( "Force a role onto a player." )
error
[ERROR] addons/terror town commands/lua/ulx/modules/sh/ttt.lua:65: 'then' expected near '=='
  1. unknown - addons/terror town commands/lua/ulx/modules/sh/ttt.lua:0
« Last Edit: May 10, 2013, 12:01:53 pm by bender180 »
Re: String arg
« Reply #1 on: May 10, 2013, 10:13:26 am »
I think you meant to do the following:
  1.     if role == "traitor" then role = ROLE_TRAITOR end
  2.     if role == "detective" then role = ROLE_DETECTIVE end
  3.     if role == "innocent" then role = ROLE_INNOCENT end
(note the second operator is "=", not "==")
Offline bender180
    • Benders Villa
Re: String arg
« Reply #2 on: May 10, 2013, 11:55:54 am »
Thanks for the fix still new and im not 100% on how the operators work.
but now im getting this error and im a little confused by it
[ERROR] addons/terror town commands/lua/ulx/modules/sh/ttt.lua:71: attempt to get length of local 'target_plys' (a userdata value)
  1. call - addons/terror town commands/lua/ulx/modules/sh/ttt.lua:71
   2. __fn - addons/ulib/lua/ulib/shared/commands.lua:943
    3. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
     4. unknown - lua/includes/modules/concommand.lua:69
« Last Edit: May 10, 2013, 12:03:08 pm by bender180 »
Re: String arg
« Reply #3 on: May 10, 2013, 02:35:39 pm »
Check the line where it adds the player arguement.
That is only checking one player, but your code needs a table of players. Use this instead.
force:addParam{ type=ULib.cmds.PlayersArg }
Offline bender180
    • Benders Villa
Re: String arg
« Reply #4 on: May 10, 2013, 02:37:09 pm »
thanks Mr.P i really need to be more through when i check my code i missed that...
Offline bender180
    • Benders Villa
Re: String arg
« Reply #5 on: May 10, 2013, 02:42:43 pm »
one last thing the echo is outputting a number where #s is do i need to change the string again?
] ulx force Bender180 detective
ServerLog: [ULX] (SILENT) Bender180 set Themself to 2
You are: DETECTIVE
(SILENT) You set Yourself to 2
« Last Edit: May 10, 2013, 02:51:30 pm by bender180 »
Re: String arg
« Reply #6 on: May 10, 2013, 03:11:18 pm »
That you'll have to wait on one of the other guys to chime in on. I never really understood how fancylog worked and there is no documentation on it as far as I know because it's ULX not ULib.
Re: String arg
« Reply #7 on: May 10, 2013, 03:23:09 pm »
To my memory, teams are numbers.
I'm guessing you'll need to use whatever function the gamemode does to look up, or set staticly in your code, team number translations.
Offline bender180
    • Benders Villa
Re: String arg
« Reply #8 on: May 10, 2013, 03:29:30 pm »
yes i had to change them back to strings from the role and the teams being numbers makes sense now.
Re: String arg
« Reply #9 on: May 10, 2013, 03:47:57 pm »
Ahh, good call Jam.
You will use team.GetName(index) to return the name of the team.
Offline bender180
    • Benders Villa
Re: String arg
« Reply #10 on: May 10, 2013, 04:42:49 pm »
Thanks Mr.P, but i just reversed this right before the fancy admin
« Last Edit: May 10, 2013, 04:44:50 pm by bender180 »
Re: String arg
« Reply #11 on: May 10, 2013, 06:54:17 pm »
Yep, just store it in another variable or something.
