Author Topic: Problem with forcedownload function in ulx2.21 / ULib1.2. Gmod9  (Read 5571 times)
Offline madsherlock
« on: January 04, 2007, 03:38:58 pm »
I have a problem with the forcedownload function.
When people connect to my srcds server, they don't download the files they should be downloading.
I put all the links to the files in the forcedownload.ini from the ulx mod. An I am pretty sure I did it the right way. I did the seperate lines and quotes thing.
Example:
"models/blah/blah.mdl"
"blah/blah/blah.vtf"
But thats not the problem.
I have installed the portal mod pack. It includes a swep, a new item (portal cube) and an edited npc (turret).
It includes a lot of models and materials wich i have installed the right way.
But when I start my server it stops when loading ulx.
It stops at end.lua.
I am pretty sure its because in the bottom of end.lua it says:
-- Download menus to client
ULib.forceDownload( "materials/ULib/menu.vtf" )
ULib.forceDownload( "materials/ULib/menu.vmt" )
ULib.forceDownload( "materials/ulx/title.vtf" )
ULib.forceDownload( "materials/ulx/title.vmt" )
Im not sure if I'm correct but I think the ulx forcedownload.ini uses the ulb forcedownload function?
Cuz in end.lua it says this:
-- This takes care of the things in the configs directory.
if not _file.Exists( "lua/ulx/configs/forcedownload.ini" ) then
   ULib.print( "[ULX] ERROR: The forcedownload.ini file is missing!" )
   local file = ULib.stripComments( _file.Read( "lua/ulx/configs/forcedownload.ini" ), "//" )
   local lines = ULib.explode( file, "\n+" )
   for _, line in pairs( lines ) do
      local data = ULib.stripQuotes( string.gsub( line, "^.*(%b\"\").*$", "%1" ) )
      if data and data ~= "" then
         ULib.forceDownload( data )
I tried removing those two parts of end.lua, and then my server does not freeze when starting. But then, of course, people can't download the stuff.
One other thing I tried was to put a .lua file in the lua/init/  folder. I called it portaldownloads.lua  and heres how I made it.
_OpenScript( "ULib/init.lua" )
ULib.forceDownload( "models/blah/justanexample.mdl" )
ULib.forceDownload( "materials/justanexample.vmt" )
I really hope, I can get serious help so..
Anybody know how I can make the forcedownload function work? (Make clients download the necessary files for the Portal pack) ;D
Re: Problem with forcedownload function in ulx2.21 / ULib1.2. Gmod9
« Reply #1 on: January 04, 2007, 04:14:59 pm »
Show us the error it's having on end.lua
Offline madsherlock
« Reply #2 on: January 05, 2007, 03:21:16 am »
k, heres the error in the srcds console if thats the one you mean. It loads up normally and then it freezez for a couple of minutes when loading end.lua:
[ULIB] Loading module: ulx_init.lua
//            ULX               //
// Loading...                 //
//  base.lua                  //
//  util.lua                    //
//  fun.lua                   //
//  cleanup.lua              //
//  menu_skin.lua          //
//  menus.lua              //
//  vote.lua                 //
//  ulib_plugin.lua         //
//  timed.lua               //
//  log.lua                   //
//  end.lua                 //
(And it just stops doing anything here..)
(Then after about 5 minutes it just skips it and continues..)
Lua error: not enough memory
(Continuing with loading the server..)
But Im pretty sure its only a problem if there's forcedownload. Cuz when I remove the lines with forcedownload from end.lua theres no problem. Except that people cant download the files XO
I don't know how to fix it? Could it be something with the .res file ?
Offline madsherlock
« Reply #3 on: January 05, 2007, 04:32:05 am »
If the files I want clients to download have a ztmp file with the same name.
Does the ztmp file mean that its a "forcedownload" file ?
