Author Topic: Name Change  (Read 6517 times)
Offline PAL-18
Name Change
« on: May 14, 2013, 04:57:29 pm »
The ability to change the name of players would be great.
P.S. This has already been requested before, but rather than necro'ing an 8 year old thread i figured i would make a new one.
Re: Name Change
« Reply #1 on: May 14, 2013, 06:52:13 pm »
This is not possible in gmod anymore since garry switched over to steam names.
The only way a server has any control over a player's name is if the server has some kind of custom name display, like some RP servers.
Offline PAL-18
Re: Name Change
« Reply #2 on: May 15, 2013, 02:20:06 am »
Thing is though, in TF2/CSS, i could do that in Sourcemod and Gmod uses the same (albeit customized) engine.
The name changes in TF2/CSS only lasted for the duration of the map and when it changed it displayed whatever the user had set in their Steam.
Re: Name Change
« Reply #3 on: May 15, 2013, 02:45:39 am »
I'm fairly sure that you can't do it in garrysmod. I don't even think a player can change their own name in the console anymore. I might be wrong though.
Offline Mors Quaedam
Re: Name Change
« Reply #4 on: May 15, 2013, 02:50:53 pm »
As far as I know this was only possible with SM (Unfortunately)
I guess you could modify the chat, but that'd break gamemodes like TTT.
Re: Name Change
« Reply #5 on: May 15, 2013, 07:28:11 pm »
We generally avoid modifying chat.
Too many other addons attempt to modify, only some with partial success, and others that totally foul up other working chat code.
