Author Topic: ULX mod wont work  (Read 6817 times)
Offline hello123
ULX mod wont work
« on: January 05, 2007, 01:10:36 pm »
I've created a server, after downloading this mod, and I cannot get this to run. Is this for Garry's mod 10 only? Also when I type the Lua_print thing, It says: unknown command. Can anyone help?
Offline madsherlock
Re: ULX mod wont work
« Reply #1 on: January 05, 2007, 03:28:02 pm »
If your using gmod9 dedicated server then you need ULib v 1.2 and ULX v 2.21. Those are the latest for gmod9.
First download and install ULib and the ULX. If you need help installing then read the readme's in the zips.
When you have installed them open up users.ini wich is somewhere in the Lua/Ulib folder. In ther, type your SteamID or whatever you want, so that u can be admin on your server.
Now ULX should work fine. In the server console it should load the ULib and ULX.
If it does not, check the lua/init folder. In there should be this file: ulib_init.lua
That's the file loading ulib at server startup. But I think you aleready know that..
And if it still does not work check if lua/ulib/modules/ulx_init.lua is there. If it is not you haven't installed ulx right and you should do it again following the steps in the readme.
I hope this makes ulx work for your server.  ;)
Offline hello123
« Reply #2 on: January 05, 2007, 07:57:45 pm »
What do i type to add an admin? This: Admin = (steam id)
Edit: Works nevermind
« Last Edit: January 05, 2007, 08:19:33 pm by hello123 »
Offline Mank
    • Ulysses Mod!
« Reply #3 on: January 06, 2007, 04:56:20 am »
Please note you only need to put your SteamID in for dedicated servers.
