Author Topic: ULX MoTD will not disable  (Read 4165 times)
Offline Epsilon
« on: June 07, 2013, 02:39:49 pm »
It appears that since the latest update to GM, ULX has started to ignore the "ulx showMotd 0" cvar that I have been using in the server.cfg file to disable ULX's MoTD. Anyone know of a workaround to make it stay disabled?
Re: ULX MoTD will not disable
« Reply #1 on: June 07, 2013, 04:02:11 pm »
The best place for ULX settings isn't the Source server server.cfg, it's in ULX's <your server gmod path>/data/ulx/config.txt
If you don't have one, copy the default one from <your server gmod path>/addons/ulx/data/ulx/config.txt to the path above, then you can edit that.
I also believe there's probably a way to edit the setting in XGUI too.
