Author Topic: Gag & mute.  (Read 5741 times)
Offline Spider
Gag & mute.
« on: June 18, 2013, 10:44:48 am »
I need a command that gags AND mutes the player with one command. I'm new to coding ulx, and this is what I came up with and it failed horribly.
function ulx.mute2( calling_ply, target_plys )
   local affected_plys = {}
   for i=1, #target_plys do
      local v = target_plys[ i ]
      v:ConCommand:("ulx gag")
      v:ConCommand:("ulx mute")
   ulx.fancyLogAdmin( calling_ply, "#A gagged and muted #T!", command, target_plys )
local mute2= ulx.command( "Zero's Commands", "ulx mute2", ulx.mute2, "!mute2" )
mute2:defaultAccess( ULib.ACCESS_SUPERADMIN )
mute2:help( "Gags and mutes the target." )
My main problem is how to get the v:ConCommand("ulx gag") to target someone.
« Last Edit: June 18, 2013, 10:47:47 am by Spider »
Re: Gag & mute.
« Reply #1 on: June 18, 2013, 12:41:18 pm »
Try
  1. calling_ply:ConCommand( "ulx gag $" .. v:UniqueID() )
The '$' is part of the targeting system to target by player ID. Also, you're missing an end at the end of the for loop.
Re: Gag & mute.
« Reply #2 on: June 18, 2013, 03:53:03 pm »
Heck, he's missing the target parameter in creation of the ulx command object.
Spider, see the [new stuff here] section of /index.php/topic,4464.0.html#msg17838 />
