Author Topic: easy way to add admins and for you to use  (Read 6392 times)
Offline amburgers
« on: January 06, 2007, 06:01:47 pm »
http://garrysmod.com/wiki/?title=Admin#Dedicated_Servers
copy the add admin layout thing what i show under my post under dedicated server into your garrysmod/settings/user txt make shure the spaces and everything are perfect.  When you make your self admin make shure your name is the first one on the list then everyone elses.  You can put your name in both admin and superadmin and restart your server and you should have admin client and admin. Also clear out garry and user2 and you have to have your steamid and everything perfect id say try starting from the "user" at the top and put everything under it
"Users"
        "superadmin"
           "amburgers and wootbeer"      "STEAM_0:0:6724541"
           "Snoop-Stabby-Stabb"             "STEAM_0:0:3555994"
   "admin"
this is how mine looks but the spacing after the { is diffrent copy the spacing from the example on wiki  the spacing is probally as big as indenting a paragraph but get it from the dedicated server users example
« Last Edit: January 06, 2007, 07:54:44 pm by amburgers »
Offline amburgers
Re: easy way to add admins and for you to use
« Reply #1 on: January 06, 2007, 06:18:57 pm »
and if anyone  asks i made it because its easier to understand than the one megiddo made
*never understood his in the first place i made a guess when i added my friend and he was able to use and i wasn't because he was in the first spot*
Offline Sgt.Magnum
« Reply #2 on: January 15, 2007, 05:06:09 am »
o man dude your my hero at the moment I've been trying to figure this out all day, THANKS ;D
Offline amburgers
« Reply #3 on: January 22, 2007, 07:48:11 am »
your welcome
