Poll
Was this module useful, and helpful?
Yes :)
93 (94.9%)
No :(
5 (5.1%)
Total Members Voted: 0
Author Topic: URL Playsound Addon :) [2.28v]  (Read 356254 times)
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: URL Playsound Addon 2.0 :)
« Reply #30 on: July 30, 2013, 03:10:38 pm »
This is the only thing that comes up in my console when its starting that has to do with playurl
http://pastebin.com/YmaSC2WM
ULX has it's way loading in console. If you don't see this ULX loading, then something is wrong with your ULX.
http://puu.sh/3PKdi.png
Also, at the bottom of that picture you'll see a lines called "MODULE: " loading at the bottom, and if you don't see "MODULE: playurl.lua" or "MODULE: playthesound.lua" not loading, then something is wrong in general.
Offline nak0604
« Reply #31 on: July 30, 2013, 05:32:24 pm »
ulx shows that everything is loading
ULX loading: http://pastebin.com/Tf57RynH
« Reply #32 on: July 30, 2013, 06:59:20 pm »
Nak, READ what Chaos said in his last post.
The last bit of loading you posted does not have those modules loaded, so, no, everything is not loading for you.
Also, reports.lua is broken, no idea what it is, but it's not one of our releases..it needs to be fixed.
« Reply #33 on: July 30, 2013, 08:33:20 pm »
As JamminR has stated. This is out of my control, you must not be using an Official version of ULX (or some really old version). The current version of ULX is 3.61 and ULiB is 2.51. So if you don't have that version or the official version, then you could be running into the problem you are having.
You can download newer and official versions of ULX here -> http://ulyssesmod.net/downloads.php <-
So I would suggest deleting your current version, and download the official and newer version of ULX so plugins (modules) for ULX will work correctly.
Thanks for choosing Apple Innovations.
« Last Edit: July 30, 2013, 08:35:00 pm by chaos13125 »
Offline nak0604
« Reply #34 on: July 30, 2013, 09:48:18 pm »
chaos i have the latest version according the the SVN that they have
« Reply #35 on: July 31, 2013, 02:00:49 am »
Are you sure your using the official SVN for ulx and Ulib, if so then delete the folder and redownload it from SVN.
Offline nak0604
« Reply #36 on: July 31, 2013, 10:41:35 am »
Yes i am, i will try re-downloading it and let you know if anything changes.
EDIT:It is at revision 161, i re-downloaded ulx and ulib and it still wont load the playurl, im just going to give up on this. Thanks for attempting to help.
« Last Edit: July 31, 2013, 10:50:15 am by nak0604 »
« Reply #37 on: July 31, 2013, 06:45:58 pm »
Sorry to hear that it didn't work out. Well there is one last thing, if you're still up for it. Somewhere in your addons, there is a addon conflicting with ulx, or maybe in the garrysmod/lua folder itself.
« Reply #38 on: August 02, 2013, 10:28:25 pm »
Talking about the entity I suggested in an earlier reply. It would be possible if you had it change volume based on distance, and disable if the volume is too low or some thing.
« Reply #39 on: August 02, 2013, 10:32:44 pm »
As far as I want to put effort into turning Garry's function into something way more.. effort forward, I see it as impossible, thus making me not want to do it.
« Reply #40 on: August 03, 2013, 03:55:07 am »
Does Ent:EmitSound not adjust volume as you get farther away?
Seems silly Garry would just have full volume up to 'range' then cut off.
« Reply #41 on: August 03, 2013, 01:40:51 pm »
It's been sometime since I've worked with lua now. I'm not really up to the challenge to somehow convert or modify an external url sound into a server sound, so this entity can use it without issues. Though, this is an interesting thing you've shown me 'Ent:EmitSound', maybe one day I might come back and look into it.
Lastly, (this might not really make sense to some people, but it does to me) I've never really gone into or really even tested that type of lua usage. I've always more 'favored' server side lua(and have been better at that), rather than client side. As well as an actual entity.
Offline morten7000
« Reply #42 on: August 12, 2013, 10:51:07 am »
Can you guyz suggest a webpage which allow you to transfer a sound into a playable link which you can play on your server?
I tried dropbox... I cant get it to work for some reason??
Edit: I tried to see If I could find a webpage "like dropbox" how transformed the mp3 to a url that acutually worked :D... I got no luck.
So if you could send me to a webpage who is making a useable link, that would make my day :)
Ps: Dont tell me to make my own webpage and host it from there :P
Thanks :D
« Last Edit: August 12, 2013, 11:43:41 am by morten7000 »
« Reply #43 on: August 12, 2013, 02:55:43 pm »
Thanks :D
Can you send me the link to that dropbox of the song you're trying to use. Also after that, you can try to use archive.org, which is what I would use.
Offline morten7000
« Reply #44 on: August 13, 2013, 04:57:25 am »
-snip-
I finally got it to work :D
« Last Edit: August 13, 2013, 06:35:54 am by morten7000 »
