Author Topic: A better noclip for admins  (Read 37640 times)
Offline Hyperion
« on: July 10, 2013, 06:02:54 am »
I want the noclip to work a little bit better for admins, so that when sbox_noclip is set to 0, then admins who have the noclip command enabled can just press V and fly, like it was at ASSMod. I know I can do 'bind v "ulx noclip"' in console, but sometimes I get into servers with no ULX and I would have to rebind everytime
Re: A better noclip for admins
« Reply #1 on: July 10, 2013, 07:34:32 am »
In assmod they would have had to overwrite the noclip function at the core level to achieve this. This is not what ULX was meant to do. There are quite a few unbound keys in gmod. Maybe bind another key to ulx noclip?
« Reply #2 on: July 10, 2013, 06:01:54 pm »
Try putting this code in your lua/autorun folder.
hook.Add( "PlayerNoClip", "ULXNoclipConversion", function(ply)
ply:ConCommand("ulx noclip")
end)
« Reply #3 on: July 11, 2013, 09:12:21 am »
end)
You should really just query the player directly instead of running the command if you want to go this route. By doing the query, you won't break client side prediction. :P
Offline Hyperion
« Reply #4 on: August 10, 2013, 09:06:55 am »
So what do you suggest? Can you give me the better code? And I have to put it in the ULX lua/autorun folder in addons, right?
« Reply #5 on: August 10, 2013, 09:47:45 am »
Use the same hook, you just want to go based off what the following call returns:
  1. ply:query("ulx noclip")
Offline nofear1999
« Reply #6 on: December 13, 2013, 12:57:57 pm »
(I know I'm bumping an old thread but I have a suggestion)
Instead of binding just ulx noclip, or noclip. why not bind both to the same button?
bind v "ulx noclip;noclip"
