Author Topic: Commands  (Read 3938 times)
Offline nak0604
Commands
« on: July 11, 2013, 09:23:09 pm »
Hello, ive been looking around and i cant seem to find any sort of list of commands that i could use in-game chat. Is there somewhere i might of overlooked or a post somewhere?
Re: Commands
« Reply #1 on: July 11, 2013, 11:40:43 pm »
Most commands (if not all) ULX commands are basically like this in console, this example, slay: ulx slay *Name*.
Now you can also do this in chat, because it may be a bit easier, and again, most commands (again, if not all) are able to be done through this in chat, same example, slay: !slay *Name*
If you're a superadmin on the server you've hosted ULX on, the only thing you need to do is to do "ulx help" in console and you'll see a list of all the ULX commands you can use.
Full list of ULX commands are in this thread: Click here.
Re: Commands
« Reply #2 on: July 14, 2013, 01:43:23 pm »
Decicus is right, and the chat commands are documented in "ulx help", too.
Re: Commands
« Reply #3 on: July 14, 2013, 02:07:16 pm »
And "ulx help" is documented in ULX's readme.txt file, which, you surely read every readme.txt file from every addon you download, because, they usually contain a key bit of information needed to use the addon as created by any mod author, right?
I'm sure you just forgot about that command.
