Thanks this worked but i realised that it only works if you set access in the TAB menu, to ULX
. I also would love if it appeared in the menu, but when you click on it, it says donator only. This partially works in the TAB menu, when you goto setjob parkour and your not goldvip, but no one ever uses TAB menu :/. I also would love to convert the code to ULX while keeping the "this is dontor only" custom check.
If you are willing to help, please make the TAB menu priority.
Thanks XD
I will try to convert to ULX myself....
