Author Topic: admin menu  (Read 8272 times)
Offline amburgers
admin menu
« on: January 08, 2007, 07:14:32 pm »
ok im not shure if its just ulx not working steam upddate or me but it started today when i go into the admin menu and try to change the props and turn on and of noclip it doesnt work it doesnt say the sbox_noclip 1 or whatever and it doesnt change :( and i dont know whats wrong
EscudoDenali
Re: admin menu
« Reply #1 on: January 08, 2007, 07:38:48 pm »
yeah, i noticed that, i wanted to change the amount of SENTS, and every time i changed it it just went back to how it was before!
Re: admin menu
« Reply #2 on: January 08, 2007, 08:32:16 pm »
Yes this is caused by the update.
Offline amburgers
Re: admin menu
« Reply #3 on: January 09, 2007, 07:52:51 am »
oooooo pooo everyone asks me to change stuff on my serve :(
Offline spbogie
Re: admin menu
« Reply #4 on: January 09, 2007, 03:53:05 pm »
You should still be able to use the chat command "!rcon sbox_noclip 1", "!rcon sbox_maxprops 100", etc.
Re: admin menu
« Reply #5 on: January 09, 2007, 10:30:55 pm »
Sorry spbogie, it's blocked server side. :(
Offline amburgers
Re: admin menu
« Reply #6 on: January 10, 2007, 05:30:01 pm »
the console commands and everything dont worlk is that what your saying?
Re: admin menu
« Reply #7 on: January 10, 2007, 06:41:24 pm »
Garry blocked rcon commands using sbox_, sv_, or name. This block was only client side before and we got around it with some hacks (but security-sound hacks). Unfortunately, there is no way around this one. Instead, we made a server plugin that will let us run rcon commands without the blocks.
Re: admin menu
« Reply #8 on: January 10, 2007, 07:02:24 pm »
And just so everyone knows, plans are to release this asap.
Don't ask, I know you want to, when.
S :) :) N.
Offline Mank
    • Ulysses Mod!
Re: admin menu
« Reply #9 on: January 11, 2007, 03:26:55 pm »
Can't you just use gm_sv_max_props etc?
I'm not sure what you're actually talking about, but this is my input.
