Author Topic: custom weapons  (Read 6932 times)
Offline craigst
custom weapons
« on: July 18, 2013, 06:26:51 pm »
i see all these new weapons i wana add in too the TTT map i add them to server how do i add then to weapon spawn list ? so they appear on map
Re: custom weapons
« Reply #1 on: July 19, 2013, 07:09:25 am »
Alright, so TTT weapons are like this, there is a folder with a name like: "ttt_weapon_name". Inside this folder there's a file, which is always called "shared.lua".
TTT weapons are located here: -Garry's Mod server directory-/garrysmod/gamemodes/terrortown/entities/weapons/
Drag the "ttt_weapon_name" folder into the directory I showed you. Now the weapon you added should spawn automatically, if the map supports "random weapon spawn". If it doesn't, you may have to add that yourself using the TTT Weapon Placer. A tutorial on how to do this can be found by clicking here.
Offline craigst
Re: custom weapons
« Reply #2 on: July 22, 2013, 05:17:55 am »
thank you :) !!!!!! :)
