Modified ULX Votekick
Topic: Modified ULX Votekick (Read 5678 times)
Jx9x9
July 28, 2013, 03:34:56 pm »
Is it possible for someone to make "ulx votekick" to be able to set the amount of time of the kick, such as: 5min, 10min, 20min, 30min, 60min? Also to be able to actually type the reasoning instead of choosing one of the selections? Thanks!
Megiddo
Ulysses Team Member
Project Lead
Re: Modified ULX Votekick
July 28, 2013, 04:23:56 pm »
You can already type whatever you want for the reason (give it a shot), and setting the "amount of time for a kick" is also known as a ban.
Jx9x9
Reply #2 on:
July 29, 2013, 12:50:50 am »
Thanks for the reply. Actually I want a ulx Votekick/Voteban without a permanent time limit, so I can add it to my server and make it available for users/players to voteban rdmers while an admin/mod is not on. Thanks
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
July 29, 2013, 04:26:48 am »
This is already possible.
Jx9x9
Reply #4 on:
July 29, 2013, 09:29:51 am »
I know it is already possible but I do not know how to do it. Should this be in a different sub-forum?
Stickly Man!
Ulysses Team Member
What even IS software anymore?
Reply #5 on:
July 29, 2013, 10:36:56 am »
You can do this by setting up the restrictions in XGUI on the Groups tab-- select your group from the dropdown box, click "Manage Permissions", then find and click on the "ulx votekick" or "ulx voteban" command. From there you can set a minimum/maximum value for the time as you see fit-- if you set the minimum to '1 minute' then it disables permabanning.
Alternately, you disable permaban by using this console command:
ulx groupallow admin "ulx voteban" "* 1:"
Join our Team Ulysses community discord!
https://discord.gg/gR4Uye6
Jx9x9
Reply #6 on:
July 29, 2013, 02:57:34 pm »
Do I have to enter that console command every restart?
Jx9x9
Reply #7 on:
July 29, 2013, 03:01:54 pm »
Nevermind you guys helped show me the obvious. Thanks!
