Go into -Server directory-\gamemodes\terrortown\gamemode\admin.lua. (I recommend getting Notepad++ and opening the admin.lua file with that).
Now if you open that with Notepad++, you should see the lines on the left side. Find line 105, or scroll down until you find "PrintDamagelog".
Now the default damagelog function looks like this:
local function PrintDamageLog(ply)
local pr = GetPrintFn(ply)
if (not IsValid(ply)) or ply:IsSuperAdmin() or GetRoundState() != ROUND_ACTIVE then
ServerLog(Format("%s used ttt_print_damagelog\n", IsValid(ply) and ply:Nick() or "console"))
pr("*** Damage log:\n")
if not dmglog_console:GetBool() then
pr("Damage logging for console disabled. Enable with ttt_log_damage_for_console 1.")
for k, txt in ipairs(GAMEMODE.DamageLog) do
pr(txt)
pr("*** Damage log end.")
if IsValid(ply) then
pr("You do not appear to be RCON or a superadmin, nor are we in the post-round phase!")
concommand.Add("ttt_print_damagelog", PrintDamageLog)
On line 108 (or in this case, line 4), change ply:IsSuperAdmin() to ply:IsAdmin().
It should look like this:
if (not IsValid(ply)) or ply:IsAdmin() or GetRoundState() != ROUND_ACTIVE then
pr(txt)
Although, this only works if the ULX moderator group counts as an admin. It would need to inherit from the default ULX group "admin" for this to work (or you will have to rename the admin group to moderator, then make another group above moderator and make that for admins).
That's basically how I did it on "my" server.
