Author Topic: Rank not saving  (Read 4423 times)
Offline zeroZshadow
Rank not saving
« on: August 03, 2013, 08:40:59 pm »
Sorry to hijack this topic, but i actually have the issue of ULX changes not being saved.
I've installed css and gmod through steamcmd on a virtual server running ubuntu linux
This is running on a user (not root) and seems to be working fine.
however....
When making myself superadmin through "rcon adduser zeroZshadow superadmin", i only stay this rank untill the map changes or the server resets
I've set srcds_run into debug mode, but am not getting any message in the console that shown errors or warnings about reading / writing files or other things that could identify the problem.
Im running the ulx and ulib freshly checked out from SVN.
I have tried the release versions from the zip files on the site also.
Any suggestions what i might be doing wrong?
(i have a similar setup on my desktop running windows, using the release ulx and ulib, everything works find there)
EDIT:
Some extra information
In the data folder of garrysmod, the folders "ulib, ulx, ulx_logs" exist
But they are all empty. I dont think they should be? (They arn't on my windows server)
« Last Edit: August 03, 2013, 08:43:39 pm by zeroZshadow »
Re: Rank not saving
« Reply #1 on: August 03, 2013, 09:01:02 pm »
Split from unrelated thread.
Is this DarkRP?
Re: Rank not saving
« Reply #2 on: August 03, 2013, 09:16:05 pm »
Additionally, does your user that the server runs as have write access to the gmod server's 'data' folder?
(Upon successful startup, indeed, there should be some data files in your gmod/data folder)
Any server console errors at startup?
