Author Topic: Restricting Items To A Group.  (Read 4468 times)
« on: August 07, 2013, 04:33:58 pm »
AddCSLuaFile()
local PANEL = {}
local matOverlay_Normal = Material( "gui/ContentIcon-normal.png" )
local matOverlay_Hovered = Material( "gui/ContentIcon-hovered.png" )
local matOverlay_AdminOnly = Material( "icon16/shield.png" )
AccessorFunc( PANEL, "m_Color", "Color" )
AccessorFunc( PANEL, "m_Type", "ContentType" )
AccessorFunc( PANEL, "m_SpawnName", "SpawnName" )
AccessorFunc( PANEL, "m_NPCWeapon", "NPCWeapon" )
function PANEL:Init()
self:SetDrawBackground( false )
self:SetSize( 128, 128 )
self:SetText( "" )
self:SetDoubleClickingEnabled( false )
self.Image = self:Add( "DImage" )
self.Image:SetPos( 3, 3 )
self.Image:SetSize( 128 - 6, 128 - 6 )
self.Image:SetVisible( false )
self.Label = self:Add( "DLabel" )
self.Label:Dock( BOTTOM )
self.Label:SetContentAlignment( 2 )
self.Label:DockMargin( 4, 0, 4, 10 )
self.Label:SetTextColor( Color( 255, 255, 255, 255 ) )
self.Label:SetExpensiveShadow( 1, Color( 0, 0, 0, 200 ) )
self.Border = 0
function PANEL:SetName( name )
self:SetTooltip( name )
self.Label:SetText( name )
self.m_NiceName = name;
function PANEL:SetMaterial( name )
self.m_MaterialName = name;
local mat = Material( name )
-- Look for the old style material
if ( !mat || mat:IsError() ) then
name = name:Replace( "entities/", "VGUI/entities/" )
name = name:Replace( ".png", "" )
mat = Material( name );
-- Couldn't find any material.. just return
return
self.Image:SetMaterial( mat );
function PANEL:SetAdminOnly( b )
self.AdminOnly = b
function PANEL:DoRightClick()
local pCanvas = self:GetSelectionCanvas()
if ( IsValid( pCanvas ) && pCanvas:NumSelectedChildren() > 0 ) then
return hook.Run( "SpawnlistOpenGenericMenu", pCanvas )
self:OpenMenu()
function PANEL:DoClick()
function PANEL:OpenMenu()
function PANEL:OnDepressionChanged( b )
function PANEL:Paint( w, h )
if ( self.Depressed && !self.Dragging ) then
if ( self.Border != 8 ) then
self.Border = 8
self:OnDepressionChanged( true )
if ( self.Border != 0 ) then
self.Border = 0
self:OnDepressionChanged( false )
self.Image:PaintAt( 3 + self.Border, 3 + self.Border, 128-8-self.Border*2, 128-8-self.Border*2 )
surface.SetDrawColor( 255, 255, 255, 255 )
if ( !dragndrop.IsDragging() && (self:IsHovered() || self:IsChildHovered( 2 )) ) then
surface.SetMaterial( matOverlay_Hovered )
self.Label:Hide()
surface.SetMaterial( matOverlay_Normal )
self.Label:Show()
surface.DrawTexturedRect( self.Border, self.Border, w-self.Border*2, h-self.Border*2 )
if ( self.AdminOnly ) then
surface.SetMaterial( matOverlay_AdminOnly )
surface.DrawTexturedRect( self.Border + 8, self.Border + 8, 16, 16 )
function PANEL:PaintOver( w, h )
self:DrawSelections()
function PANEL:ToTable( bigtable )
local tab = {}
tab.type = self:GetContentType();
tab.nicename = self.m_NiceName;
tab.material = self.m_MaterialName;
tab.admin = self.AdminOnly;
tab.spawnname = self:GetSpawnName();
tab.weapon = self:GetNPCWeapon();
table.insert( bigtable, tab )
function PANEL:Copy()
local copy = vgui.Create( "ContentIcon", self:GetParent() )
copy:SetContentType( self:GetContentType() )
copy:SetSpawnName( self:GetSpawnName() )
copy:SetName( self.m_NiceName )
copy:SetMaterial( self.m_MaterialName )
copy:SetNPCWeapon( self:GetNPCWeapon() )
copy:SetAdminOnly( self.AdminOnly )
copy:CopyBase( self )
copy.DoClick = self.DoClick
copy.OpenMenu = self.OpenMenu
return copy;
vgui.Register( "ContentIcon", PANEL, "DButton" )
spawnmenu.AddContentType( "entity", function( container, obj )
if ( !obj.material ) then return end
if ( !obj.nicename ) then return end
if ( !obj.spawnname ) then return end
local icon = vgui.Create( "ContentIcon", container )
icon:SetContentType( "entity" )
icon:SetSpawnName( obj.spawnname )
icon:SetName( obj.nicename )
icon:SetMaterial( obj.material )
icon:SetAdminOnly( obj.admin )
icon:SetColor( Color( 205, 92, 92, 255 ) )
icon.DoClick = function()
RunConsoleCommand( "gm_spawnsent", obj.spawnname );
surface.PlaySound( "ui/buttonclickrelease.wav" )
icon.OpenMenu = function( icon )
local menu = DermaMenu()
local SubMenu = menu:AddSubMenu( "Restrict" ) -- Add a submenu
for k,_ in pairs(ULib.ucl.groups) do
SubMenu:AddOption( tostring(k), function() RunConsoleCommand( "ulx", "restrict", tostring(k), obj.spawnname ); end ):SetIcon( "icon16/group.png" )
menu:AddSpacer()
menu:AddOption( "Copy to Clipboard", function() SetClipboardText( obj.spawnname ) end )
menu:AddOption( "Spawn Using Toolgun", function() RunConsoleCommand( "gmod_tool", "creator" ); RunConsoleCommand( "creator_type", "0" ); RunConsoleCommand( "creator_name", obj.spawnname ) end )
menu:AddSpacer()
menu:AddOption( "Delete", function() icon:Remove(); hook.Run( "SpawnlistContentChanged", icon ) end )
menu:Open()
if ( IsValid( container ) ) then
container:Add( icon )
return icon;
end )
spawnmenu.AddContentType( "vehicle", function( container, obj )
icon:SetContentType( "vehicle" )
icon:SetColor( Color( 0, 0, 0, 255 ) )
RunConsoleCommand( "gm_spawnvehicle", obj.spawnname );
menu:AddSpacer()
menu:AddOption( "Spawn Using Toolgun", function() RunConsoleCommand( "gmod_tool", "creator" ); RunConsoleCommand( "creator_type", "1" ); RunConsoleCommand( "creator_name", obj.spawnname ) end )
menu:AddSpacer()
menu:Open()
return icon;
end )
gmod_npcweapon = CreateConVar( "gmod_npcweapon", "", { FCVAR_ARCHIVE } );
spawnmenu.AddContentType( "npc", function( container, obj )
if ( !obj.weapon ) then obj.weapon = gmod_npcweapon:GetString() end
icon:SetContentType( "npc" )
icon:SetNPCWeapon( obj.weapon )
icon:SetColor( Color( 244, 164, 96, 255 ) )
local weapon = obj.weapon;
if ( gmod_npcweapon:GetString() != "" ) then weapon = gmod_npcweapon:GetString(); end
RunConsoleCommand( "gmod_spawnnpc", obj.spawnname, weapon );
menu:AddSpacer()
menu:AddOption( "Spawn Using Toolgun", function() RunConsoleCommand( "gmod_tool", "creator" ); RunConsoleCommand( "creator_type", "2" ); RunConsoleCommand( "creator_name", obj.spawnname ); RunConsoleCommand( "creator_arg", weapon ); end )
menu:AddSpacer()
menu:Open()
return icon;
end )
spawnmenu.AddContentType( "weapon", function( container, obj )
icon:SetContentType( "weapon" )
icon:SetColor( Color( 135, 206, 250, 255 ) )
RunConsoleCommand( "gm_giveswep", obj.spawnname );
icon.DoMiddleClick = function()
RunConsoleCommand( "gm_spawnswep", obj.spawnname );
menu:AddSpacer()
menu:AddOption( "Spawn Using Toolgun", function() RunConsoleCommand( "gmod_tool", "creator" ); RunConsoleCommand( "creator_type", "3" ); RunConsoleCommand( "creator_name", obj.spawnname ) end )
menu:AddSpacer()
menu:Open()
return icon;
end )
function UCanSpawnAllowedCheck( ply, ent, istool )
local usergroup = ply:GetNetworkedVar("UserGroup") or ply:GetUserGroup() or "user"
local groupTable = ULib.ucl.groups[usergroup].restrict
if( !istool ) then
if( table.HasValue(groupTable, ent:GetClass()) or table.HasValue(groupTable, ent:GetModel()) or table.HasValue(groupTable, ent:GetType()) ) then
return false
local tool = ent
if( table.HasValue(groupTable, tool) ) then
return false
hook.Add("PlayerSpawnEffect", "UCanPlayerSpawnEffect", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnNPC", "UCanPlayerSpawnNPC", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnObject", "UCanPlayerSpawnObject", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnProp", "UCanPlayerSpawnProp", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnRagdoll", "UCanPlayerSpawnRagdoll", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnSENT", "UCanPlayerSpawnSENT", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnSWEP", "UCanPlayerSpawnSWEP", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("PlayerSpawnVehicle", "UCanPlayerSpawnVehicle", function(ply, ent) UCanSpawnAllowedCheck(ply, ent, false) end)
hook.Add("CanTool", "UCanCanTool", function(ply, _, tool) UCanSpawnAllowedCheck(ply, tool, true) end)
function ulx.restrict( calling_ply, target, command )
if( ULib.ucl.groups[target] ~= nil ) then
if( ULib.ucl.groups[target].restrict ~= nil and type(ULib.ucl.groups[target].restrict) == "table" ) then
table.insert( ULib.ucl.groups[target].restrict, command )
ULib.ucl.groups[target].restrict = { command }
ULib.tsayError( calling_ply, "Error: Group Not Found" )
return false
ulx.fancyLogAdmin( calling_ply, "#A restricted #s from #T", command, target )
local restrict = ulx.command( "Utility", "ulx restrict", ulx.restrict, "!restrict" )
restrict:addParam{ type=ULib.cmds.StringArg, completes=ulx.group_names_no_user, hint="group", error="invalid group \"%s\" specified", ULib.cmds.restrictToCompletes }
restrict:addParam{ type=ULib.cmds.StringArg, hint="command", ULib.cmds.takeRestOfLine }
restrict:defaultAccess( ULib.ACCESS_SUPERADMIN )
restrict:help( "Restrict something from a target(s)." )
I was wondering if any one had any suggestions on what I can do with the above code, I know overrides are bad but I could not think of a way of doing what I wanted to do without overriding.
Any suggestions/code fixes would be appreciated. (This is untested.)
Also on a some how slightly related topic does URS still work?
« Last Edit: August 07, 2013, 05:02:47 pm by HeLLFox_15 »
Re: Restricting Items To A Group.
« Reply #1 on: August 09, 2013, 07:34:56 am »
It's not in the documentation (though it should be), but I'd recommend calling ULib.ucl.saveGroups() after modifying the groups table. Your use of hooks is good, it is what the hooks are intended for. You may want to give the user feedback on why they can't spawn certain things, though.
