Author Topic: Disappearing commands written in chat?  (Read 3647 times)
Offline Hyperion
« on: August 10, 2013, 09:12:32 am »
Whenever someone with a low rank writes a command that is not available for him, for example !noclip while being a guest on my server, it tells him that he can't use it, and the command also doesn't appear in the chat. But is it possible to make the text go disappear from chat also if someone writes a command which he is allowed to use it? While the console still showing who used what command, to admins?
Re: Disappearing commands written in chat?
« Reply #1 on: August 10, 2013, 09:25:25 am »
We try not to modify chat hook much, so no, there is no current way to do what you're asking within ULX.
The reason the guest user commands are never seen now is due to the fact we stop execution of the chat hook.
Once you go into actually modifying whether or not what is typed is seen or not based on rank, it can really complicate matters in the chat system, especially if there is another mod that monitors chat hooks in some way.
Over the years, our recommendation for not wanting to see commands issued is to use the game console, and/or XGUI.
Setting logEcho mode appropriately will also help.
« Reply #2 on: August 10, 2013, 09:46:16 am »
Actually, whether or not a command is hidden in chat is set when the command is setup. Like this:
  1. local asay = ulx.command( CATEGORY_NAME, "ulx asay", ulx.asay, "@", true, true )
The first true (fifth overall argument) is telling ULX that asay's need to be hidden from chat.
« Reply #3 on: August 10, 2013, 09:55:35 am »
But overall, we've not set a console variable that would control all our function calls/setup.
One would require going in and editing our code to do so.
