Author Topic: No ULX Download.txt  (Read 5047 times)
No ULX Download.txt
« on: August 12, 2013, 04:55:10 am »
The Download.txt for ULX is not being created on my server. Currently I am running Xenon and they say that the latest versions of ULX and ULib that they have are... 2013-06-24.
Should I try uploading the ULX I have on my client? Or is there a reason why that file is not being created?
I will be switching to NFOServers when I can.
Also if any one knows any good server hosts that are cheap please tell me.
Re: No ULX Download.txt
« Reply #1 on: August 12, 2013, 05:14:11 am »
Why not copy and paste it over? I don't believe we explicitly create it.
« Reply #2 on: August 12, 2013, 09:42:44 am »
I will try thanks. Also I am a little new to FastDL would I have to include the maps in there too or?
« Reply #3 on: August 12, 2013, 10:05:24 am »
That shouldn't be needed. You should only need to compress the map to .bz2 (bzip2) and upload it to the web server for fast dl to properly work with maps.
« Reply #4 on: August 12, 2013, 02:24:27 pm »
Shouldn't need to even include maps in downloads.txt.
Maps will automatically download if the fastdl has it when a player joins if he/she doesn't already have that map.
Downloads.txt is primarily meant for one-off sounds, models, etc not already part of a addon or pack.
Sure, you could USE it for maps, but I'd hate to join a server that forced me to download 10 maps when I first joined, to never return after one map.
« Reply #5 on: August 12, 2013, 04:36:38 pm »
Jam is correct.
Maps don't need to be added to the downloads.txt file. They DO however, need to be added to the FastDL directory.
« Reply #6 on: August 13, 2013, 12:10:52 am »
Jam is correct.
I guess its time to start extracting from the workshop... and thanks. (Speaking of that Garry needs to make FastDL work with workshop items.)
