Author Topic: Votemap settings are correct but all maps appear in Excluded list on server  (Read 6392 times)
Offline Storm
I know ULX pretty well by now but I have an odd problem I can't seem to fix.  In data/ulx/votemap.txt I have listed the maps I don't want players to vote on. In data/ulx/config.txt I have both ulx votemapEnabled and votemapMode set to 1. I have also tried setting this the other way (votemap.txt with maps I do want and votemapMode on 2).  The problem is when I join the server and go in ulx to settings, ULX PLayer Votemap List, all my maps appear in the Excluded Votemaps list, so players can't vote to change the map. I can then move them over manually but when the map changes, or the server restarts, all the maps return to the Excluded list, and again players can't vote. I have 7 GMod servers and this is only happening on one TTT server. It actually works fine on the other 4 TTT servers. I even copied the votemap.txt and config.txt files from a working server to this one and it was ineffective. Any help would be greatly appreciated!
That's odd that it works on some and not others. Do you know if the one that it's not working on is a Linux host, by chance?
Offline Storm
The one it is not working on is Windows. It is working on the other Windows servers I have and I have one Linux server and it is working on there. I am stumped! I have spent hours trying to solve this.
Are you running the exact same version (SVN, as the 'release' download is broken) of ULX on all servers?
Offline Storm
6 of the GMod servers have the same host which has svn repositories. One click downloads the ulx addon. All 6 have the same ulx svn version. Only one won't work. Also, the TTT servers are identical in everyway, as far as addons and configurations. The number of players is different but that's all.
Hmmm, I would need to debug the problem directly on your server, I think. If you're comfortable with that (I would need Rcon), is there an evening next week we could schedule a time to look at this? An evening relative to Mountain time.
Offline Storm
I will try to completely reinstall ULX. Would I have to reinstall ULIB as well?
If you want to be thorough, yes.
