Author Topic: Problem with custom ttt_print_traitors command... Help?  (Read 4587 times)
Twistedwheelbarrow
« on: August 16, 2013, 02:42:28 pm »
I'm trying to figure out the code below so that when the command is used, it only prints the traitors. Once I have done this, I want to be able to print the traitors, showing their status... E.g, dead traitors appear a different colour to living?
local function TraitorSort(a,b)
   if not IsValid(a) then return true end
   if not IsValid(b) then return false end
   if a:GetTraitor() and (not b:GetTraitor()) then return true end
   if b:GetTraitor() and (not a:GetTraitor()) then return false end
   return false
function PrintTraitors(ply)
   if not IsValid(ply) or ply:IsSuperAdmin() then
      ServerLog(Format("%s used ttt_print_traitors\n", IsValid(ply) and ply:Nick() or "console"))
      local pr = GetPrintFn(ply)
      local ps = player.GetAll()
      table.sort(ps, TraitorSort)
      for _, p in pairs(ps) do
         if IsValid(p) then
            pr(p:GetTraitor() and "TRAITOR" or "Innocent", ":", p:Nick())
concommand.Add("ttt_print_traitors", PrintTraitors)
