Author Topic: Could Never Get This Working...  (Read 6042 times)
« on: August 16, 2013, 09:23:45 pm »
Lets say I have a table like this...
James = {"James", "loves", "pie", "but", "JamminR", "likes", "jam"}
What would I do to make this output in order with a 1 second delay between each output.
As in...
"James"
-- One Second Later
"loves"
-- One Second Later
"pie"
-- You get the idea...
The above used to be easy to do but long ago an update to the timers broke my method of doing that. Any ideas?
Re: Could Never Get This Working...
« Reply #1 on: August 16, 2013, 09:39:22 pm »
No idea what's broken in timers.
If simple.timer works;
for i, blah in ipairs( James )
  timer.Simple ( i, <print/msg/say/whatever code to display>( blah ) )
« Reply #2 on: August 16, 2013, 10:27:00 pm »
Here is the problem though...
Attempt to concatenate local 'v' (a nil value)
for i, v in ipairs( James ) do
  timer.Simple ( i, function(v) print("Value: " .. v) end)
« Reply #3 on: August 16, 2013, 10:30:40 pm »
take v out of your function()
You're not passing anything through it, you don't need it.
At that point it's trying to find what v is equal to when it goes to print the value using the value that is passing through the function (which doesn't exist)
« Reply #4 on: August 16, 2013, 10:37:41 pm »
Thanks MrPresident, I knew I was missing some thing...
