Author Topic: Ulx doesnt save any admins when map changes  (Read 4094 times)
Offline Voltage
« on: August 22, 2013, 11:18:28 pm »
So whenever i change the map on ttt it wont save me as owner or anyone else itll put me as super admin but what will happen is when i type !menu nothing comes up in the commands. I can't seem to figure it out i think i installed it wrong not sure but if you can help that would be great!
Offline rainbow Dash
    • Friendship is Gaming
Re: Ulx doesnt save any admins when map changes
« Reply #1 on: August 22, 2013, 11:25:40 pm »
bug with changing gamemodes i hear. The only solution I have is delete ULX from your server completely, including the appropriate saved data, and re-install. This is how i fixed it when I had it happen to me. If you wish to change gamemodes, dont use ULX to do it. Avoid it at all costs.
Uhm, whats a signature?
Offline Voltage
« Reply #2 on: August 23, 2013, 12:12:22 am »
I already had it set to ttt its just like whenever i change the map itll just completely remove everything it says im a super admin but like i dont see any commands.
« Reply #3 on: August 23, 2013, 02:01:16 pm »
Make sure you're using SVN of ULX/ulib.
« Reply #4 on: August 27, 2013, 06:51:09 pm »
It has nothing to do with using ULX to change gamemodes, it's just a GM bug with changing gamemodes in general. But we worked around it in SVN.
