Author Topic: Gun Admin Check  (Read 65569 times)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Gun Admin Check
« on: December 17, 2005, 02:49:29 pm »
This script will check to see if your an admin on a certain list and kill you if you are not supposed to have the gun.
Installation:
Find the script of the gun you want to use. (ex: gmod9/lua/weapons/bangun/bangun.lua)
Find the part that says (or something similar)
-- Called when player picks up weapon
function onPickup( userid )
Copy everything from 'function' to 'end' and delete it, so you should be deleting this:
Now where that originally was, paste this:
function onPickup( pickerup )
_OpenScript( "wepadminlist.lua" );
if (_PlayerInfo( pickerup, "networkid" ) == AUTHID1) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID2) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID3) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID4) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID5) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID6) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID7) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID8) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID9) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID10) or
(_PlayerInfo( pickerup, "networkid" ) == AUTHID11) then
     _Msg( "Authorized." )
    _Msg( "No acess!" )
    _ScreenText( pickerup, "You do not have permission to use this weapon",0, 0, 255,0,0,255,1,1,2,1,0)
_PlayerSilentKill( pickerup, 1, true )
Now, create a new lua file called 'wepadminlist' (It must be called this and must be in the same folder as the weapons it is used in).
Inside, paste this:
AUTHID1 = "Steam ID Here";
AUTHID2 = "Steam ID Here";
AUTHID3 = "Steam ID Here";
AUTHID4 = "Steam ID Here";
AUTHID5 = "Steam ID Here";
AUTHID6 = "Steam ID Here";
AUTHID7 = "Steam ID Here";
AUTHID8 = "Steam ID Here";
AUTHID9 = "Steam ID Here";
AUTHID10 = "Steam ID Here";
AUTHID11 = "Steam ID Here";
For every admin, replace the part inside the quotes that says Steam ID Here, and replace it with the admin's steamid.
and your done.
« Last Edit: March 29, 2006, 10:31:39 pm by Golden-Death »
Offline Jesusaurus-Rex
Re: Gun Admin Check
« Reply #1 on: December 17, 2005, 02:52:21 pm »
Oh, nice work, maybe Meggeh could help you use the ULX admin list.
Offline Mank
    • Ulysses Mod!
Re: Gun Admin Check
« Reply #2 on: December 17, 2005, 03:21:17 pm »
Use _PlayerSilentKill instead.  It kills em even when they have buddha.
Re: Gun Admin Check
« Reply #3 on: December 17, 2005, 07:15:06 pm »
Uh... please use ULX for that user list... that's terrible. Read the docs at http://wiki.ulyssesmod.net/
    • BlueFire
Re: Gun Admin Check
« Reply #4 on: December 17, 2005, 08:42:35 pm »
redid it
Offline Mank
    • Ulysses Mod!
Re: Gun Admin Check
« Reply #5 on: December 18, 2005, 03:32:02 am »
Nice one.
Re: Gun Admin Check
« Reply #6 on: February 10, 2006, 02:13:59 pm »
Please update this plugin to use ULX v1.1's new module system
Atomix
Re: Gun Admin Check
« Reply #7 on: February 20, 2006, 09:41:34 am »
I put it at the top of all my admin only guns, and anyone can still pick them up, and in the master console it just says.
[LUA] Error calling 'onPickup' : 'Line 3: attempt to call global 'hasAccess' <anil value>'
can someone tell me what I'm doing wrong?
Thank youuuu
-Atomix
    • BlueFire
Re: Gun Admin Check
« Reply #8 on: February 20, 2006, 10:32:23 am »
Its probobly because meg has changed the code for the new version. Ill see what I can do to update it.
Re: Gun Admin Check
« Reply #9 on: February 20, 2006, 11:03:30 am »
Nope, hasAccess still exists, if it says it's nil he's probably not using ULX.
    • BlueFire
Re: Gun Admin Check
« Reply #10 on: February 20, 2006, 11:07:04 am »
Ah, yes you need ULX to use this.
Mascot105
Re: Gun Admin Check
« Reply #11 on: March 11, 2006, 08:43:43 pm »
Thanks SOOOO Much!.
Very Very Very usuful for construct servers.
Slayer_NL
Re: Gun Admin Check
« Reply #12 on: March 25, 2006, 09:14:20 am »
Could you please explain a bit more.
I have downloaded ULX 1.1 and set up correctly because im admin.
I have putten the script above the .lua from the weapon and i get the same error as Atomix.
Please explain a bit better what I'm doing wrong.
    • BlueFire
Re: Gun Admin Check
« Reply #13 on: March 25, 2006, 09:26:33 am »
Do you have ULX installed and working correctly?
Slayer_NL
Re: Gun Admin Check
« Reply #14 on: March 25, 2006, 10:34:58 am »
Well i think so I am admin and all commands are working so i think it's installed correctly.
