Author Topic: ULX scoreboard and text color help TTT server  (Read 49697 times)
Offline DJ Mikey
Re: ULX scoreboard and text color help TTT server
« Reply #15 on: August 30, 2013, 07:15:42 pm »
I got everything working now.  Boy does it look neat!  Thank you all for the help!
« Reply #16 on: August 31, 2013, 03:33:56 am »
I completely forgot I about this, sorry man. I had other things on my mind at the time. Although, I'm happy that you got it fixed! What did you do to fix it? (Just out of curiousity)
Offline iSnipeu
« Reply #17 on: August 31, 2013, 05:08:11 am »
You do not need to change default TTT files to get it working, just use a hook.
hook.Add("TTTScoreboardColorForPlayer", "RankColours", function( ply )
if ply:SteamID() == "STEAM_0:0:0000000" then
return Color( 153, 255, 255 )
end)
« Reply #18 on: August 31, 2013, 06:53:30 am »
I don't see how that would work, care to explain?
Offline iSnipeu
« Reply #19 on: August 31, 2013, 07:31:22 am »
TTT has hooks you can use so you don't have to edit the gamemode for general things.
Quote from: http://ttt.badking.net/guides/hooks
TTTScoreboardColorForPlayer (ply)
Client
Called to determine what colour a player's name should be on the scoreboard. Hence, it must return a Color object, or return nil (or nothing at all). The "ply" parameter contains a player object, so you can for example check the player's SteamID and give certain people a special colour. Note that TTT also uses this hook for the default colours, so you should return nil for players that you do not want to do anything special with.
« Reply #20 on: August 31, 2013, 09:40:13 am »
Oh yeah, forgot about that hook.
Although, if he wanted that other column with the "Rank" or whatever, one would still need to modify the files.
Offline DJ Mikey
« Reply #21 on: August 31, 2013, 03:14:07 pm »
i actually did not need to do much.  It wasnt working at first and giving me console errors, i navigated to the lines that were generating the lua errors and simply made some minor edits.  (had some extra end's)
As far as making the rank column not over lap, i just got rid of the Super Admin text and edited it to read Owner.  Now all group names fit and i dont need to meddle around to much with the script.  All i need to do now is add an extra group to get rid of the "rank" group for normal users.  Should be easy enough now that i understand how the script works in those lines.
« Reply #22 on: August 31, 2013, 03:37:05 pm »
That is actually an easy edit, in where the ranks are, under the ones for "admin" and "superadmin". Just add this:
        elseif ply:IsUserGroup("user") then
                self.cols[5]:SetText("Player")
                self.cols[5]:SetTextColor(Color(255, 255, 255, 255))
Edit as you would like it to be.
Offline DJ Mikey
« Reply #23 on: August 31, 2013, 05:08:14 pm »
i thought for color white it was 0, 0, 0, 255
i have already added the user group to read Guest, i added another line for group "member" players gain member status upon registering to the forums!
actually heres a question
Here is what i got now
local namecolor = {
       default = COLOR_WHITE,
       admin = Color(220, 180, 0, 255),
       dev = Color(0, 100, 255, 255),
       test = Color(220, 0, 0, 255),
       member = Color(50, 255, 0, 255)
    function GM:TTTScoreboardColorForPlayer(ply)
       if not IsValid(ply) then return namecolor.default end
       --ADD NAMECOLOURS HERE--
       if ply:SteamID() == "STEAM_0:0:xxxxxxxxx" then
          return namecolor.dev
       elseif ply:SteamID() == "STEAM_0:0:xxxxxxxx" then
       elseif ply:SteamID() == "STEAM_0:1:xxxxxxxxxx" then
       elseif ply:SteamID() == "STEAM_0:1:xxxxxxxxxxx" then
       elseif ply:IsAdmin() and GetGlobalBool("ttt_highlight_admins", true) then
          return namecolor.admin
       elseif ply:IsUserGroup("superadmin") then
                    return namecolor.test
   elseif ply:IsUserGroup("member") then
                    return namecolor.member
Instead of using each persons steam id for VIP specific colors... could i just do this instead
local namecolor = {
      if ply:IsUserGroup("vip") then
It would be much easier and i wouldnt need to edit the lua for new VIPs
« Last Edit: August 31, 2013, 05:18:54 pm by DJ Mikey »
« Reply #24 on: August 31, 2013, 05:14:39 pm »
0 = absense of color.
255 = full range of color
000 = black
255255255 = white
« Reply #25 on: August 31, 2013, 05:15:44 pm »
Basically what JamminR said. It just ends up making sense somehow, and I don't want to mess with logic.
Offline DJ Mikey
« Reply #26 on: August 31, 2013, 05:20:36 pm »
darn didnt see you replied, can you look at my previous post i just edited.  Thanks!  All this lua stuff is making my brain ache, just last week i knew nothing.
« Reply #27 on: August 31, 2013, 05:23:56 pm »
If I understood it right, all the extra Steam ID's are just VIPs, and those Steam ID's/players are in their own ULX group called "vip".
Then yes, in theory that should work completely fine as long as they're inside that ULX group.
Offline DJ Mikey
« Reply #28 on: August 31, 2013, 05:24:42 pm »
fantastic, it just made more sense.
Offline DJ Mikey
« Reply #29 on: September 01, 2013, 08:59:26 am »
I am getting these following errors every time i press TAB.  It results in a crash from the server with the text "too many lua errors"
[ERROR] gamemodes/terrortown/gamemode/vgui/sb_row.lua:207: attempt to index global 'Self' (a nil value)
  1. UpdatePlayerData - gamemodes/terrortown/gamemode/vgui/sb_row.lua:207
   2. SetPlayer - gamemodes/terrortown/gamemode/vgui/sb_row.lua:174
    3. AddPlayerRow - gamemodes/terrortown/gamemode/vgui/sb_team.lua:85
     4. UpdateScoreboard - gamemodes/terrortown/gamemode/vgui/sb_main.lua:273
      5. unknown - gamemodes/terrortown/gamemode/cl_scoreboard.lua:40
      5. unknown - gamemodes/terrortown/gamemode/vgui/sb_main.lua:153
The only script i edited was sb_row.lua
Here is what i currently have that is causing the errors
    ---- Scoreboard player score row, based on sandbox version
    include("sb_info.lua")
    local GetTranslation = LANG.GetTranslation
    local GetPTranslation = LANG.GetParamTranslation
    SB_ROW_HEIGHT = 24 --16
    local PANEL = {}
    function PANEL:Init()
       -- cannot create info card until player state is known
       self.info = nil
       self.open = false
       self.cols = {}
       self.cols[1] = vgui.Create("DLabel", self)
       self.cols[1]:SetText(GetTranslation("sb_ping"))
       self.cols[2] = vgui.Create("DLabel", self)
       self.cols[2]:SetText(GetTranslation("sb_deaths"))
       self.cols[3] = vgui.Create("DLabel", self)
       self.cols[3]:SetText(GetTranslation("sb_score"))
      self.cols[5] = vgui.Create("DLabel", self)
      self.cols[5]:SetText("Rank")
       if KARMA.IsEnabled() then
          self.cols[4] = vgui.Create("DLabel", self)
          self.cols[4]:SetText(GetTranslation("sb_karma"))
       for _, c in ipairs(self.cols) do
          c:SetMouseInputEnabled(false)
       self.tag = vgui.Create("DLabel", self)
       self.tag:SetText("")
       self.tag:SetMouseInputEnabled(false)
       self.sresult = vgui.Create("DImage", self)
       self.sresult:SetSize(16,16)
       self.sresult:SetMouseInputEnabled(false)
       self.avatar = vgui.Create( "AvatarImage", self )
       self.avatar:SetSize(SB_ROW_HEIGHT, SB_ROW_HEIGHT)
       self.avatar:SetMouseInputEnabled(false)
       self.nick = vgui.Create("DLabel", self)
       self.nick:SetMouseInputEnabled(false)
       self.voice = vgui.Create("DImageButton", self)
       self.voice:SetSize(16,16)
       self:SetCursor( "hand" )
    ----EDIT THESE TO ADD MORE COLOURS----
    ----Example: test = COLOR_BLUE----
    ---Make sure to put a comma after each line until the end (Last one doesn't have one---
    local namecolor = {
       elseif ply:SteamID() == "STEAM_0:0:xxxxxxxxxx" then
       elseif ply:SteamID() == "STEAM_0:1:xxxxxxxxx" then
    local function ColorForPlayer(ply)
       if IsValid(ply) then
          local c = hook.Call("TTTScoreboardColorForPlayer", GAMEMODE, ply)
          -- verify that we got a proper color
          if c and type(c) == "table" and c.r and c.b and c.g and c.a then
             return c
             ErrorNoHalt("TTTScoreboardColorForPlayer hook returned something that isn't a color!\n")
    function PANEL:Paint()
       if not IsValid(self.Player) then return end
    --   if ( self.Player:GetFriendStatus() == "friend" ) then
    --      color = Color( 236, 181, 113, 255 )
    --   end
       local ply = self.Player
       if ply:IsTraitor() then
          surface.SetDrawColor(255, 0, 0, 30)
          surface.DrawRect(0, 0, self:GetWide(), SB_ROW_HEIGHT)
       elseif ply:IsDetective() then
          surface.SetDrawColor(0, 0, 255, 30)
       if ply == LocalPlayer() then
          surface.SetDrawColor( 200, 200, 200, math.Clamp(math.sin(RealTime() * 2) * 50, 0, 100))
          surface.DrawRect(0, 0, self:GetWide(), SB_ROW_HEIGHT )
       return true
    function PANEL:SetPlayer(ply)
       self.Player = ply
       self.avatar:SetPlayer(ply)
       if not self.info then
          local g = ScoreGroup(ply)
          if g == GROUP_TERROR and ply != LocalPlayer() then
             self.info = vgui.Create("TTTScorePlayerInfoTags", self)
             self.info:SetPlayer(ply)
             self:InvalidateLayout()
          elseif g == GROUP_FOUND or g == GROUP_NOTFOUND then
             self.info = vgui.Create("TTTScorePlayerInfoSearch", self)
       self.voice.DoClick = function()
                               if IsValid(ply) and ply != LocalPlayer() then
                                  ply:SetMuted(not ply:IsMuted())
       self:UpdatePlayerData()
    function PANEL:GetPlayer() return self.Player end
    function PANEL:UpdatePlayerData()
       self.cols[1]:SetText(ply:Ping())
       self.cols[2]:SetText(ply:Deaths())
       self.cols[3]:SetText(ply:Frags())
       if self.cols[4] then
          self.cols[4]:SetText(math.Round(ply:GetBaseKarma()))
       self.nick:SetText(ply:Nick())
       self.nick:SizeToContents()
       self.nick:SetTextColor(ColorForPlayer(ply))
                    self.cols[5]:SetText("Owner")
                    self.cols[5]:SetTextColor(namecolor.test)
            elseif ply:IsUserGroup("admin") then
                    self.cols[5]:SetText("Admin")
                    self.cols[5]:SetTextColor(Color(220, 180, 0, 255))
            elseif ply:IsUserGroup("vip") then
                    self.cols[5]:SetText("VIP")
                    self.cols[5]:SetTextColor(Color(0, 100, 255, 255))
                    self.cols[5]:SetText("Guest")
                    Self.cols[5]:SetTextColor(Color(255, 255, 255, 255))
                    self.cols[5]:SetText("Member")
                    self.cols[5]:SetTextColor(Color(50, 255, 0, 255))
    --  Delete the -- and change the settings to your liking. DO NOT DELETE THE 'end'
       local ptag = ply.sb_tag
       if ScoreGroup(ply) != GROUP_TERROR then
          ptag = nil
       self.tag:SetText(ptag and GetTranslation(ptag.txt) or "")
       self.tag:SetTextColor(ptag and ptag.color or COLOR_WHITE)
       self.sresult:SetVisible(ply.search_result != nil)
       -- more blue if a detective searched them
       if ply.search_result and (LocalPlayer():IsDetective() or (not ply.search_result.show)) then
          self.sresult:SetImageColor(Color(200, 200, 255))
       -- cols are likely to need re-centering
       self:LayoutColumns()
       if self.info then
          self.info:UpdatePlayerData()
       if self.Player != LocalPlayer() then
          local muted = self.Player:IsMuted()
          self.voice:SetImage(muted and "icon16/sound_mute.png" or "icon16/sound.png")
          self.voice:Hide()
    function PANEL:ApplySchemeSettings()
       for k,v in pairs(self.cols) do
          v:SetFont("treb_small")
          v:SetTextColor(COLOR_WHITE)
       self.nick:SetFont("treb_small")
       self.nick:SetTextColor(ColorForPlayer(self.Player))
       local ptag = self.Player and self.Player.sb_tag
       self.tag:SetFont("treb_small")
       self.sresult:SetImage("icon16/magnifier.png")
       self.sresult:SetImageColor(Color(170, 170, 170, 150))
    function PANEL:LayoutColumns()
       for k,v in ipairs(self.cols) do
          v:SizeToContents()
          v:SetPos(self:GetWide() - (50*k) - v:GetWide()/2, (SB_ROW_HEIGHT - v:GetTall()) / 2)
       self.tag:SizeToContents()
       self.tag:SetPos(self:GetWide() - (50 * 6) - self.tag:GetWide()/2, (SB_ROW_HEIGHT - self.tag:GetTall()) / 2)
       self.sresult:SetPos(self:GetWide() - (50*6) - 8, (SB_ROW_HEIGHT - 16) / 2)
    function PANEL:PerformLayout()
       self.avatar:SetPos(0,0)
       self.avatar:SetSize(SB_ROW_HEIGHT,SB_ROW_HEIGHT)
       if not self.open then
          self:SetSize(self:GetWide(), SB_ROW_HEIGHT)
          if self.info then self.info:SetVisible(false) end
       elseif self.info then
          self:SetSize(self:GetWide(), 100 + SB_ROW_HEIGHT)
          self.info:SetVisible(true)
          self.info:SetPos(5, SB_ROW_HEIGHT + 5)
          self.info:SetSize(self:GetWide(), 100)
          self.info:PerformLayout()
          self:SetSize(self:GetWide(), SB_ROW_HEIGHT + self.info:GetTall())
       self.nick:SetPos(SB_ROW_HEIGHT + 10, (SB_ROW_HEIGHT - self.nick:GetTall()) / 2)
       self.voice:SetVisible(not self.open)
       self.voice:SetSize(16, 16)
       self.voice:DockMargin(4, 4, 4, 4)
       self.voice:Dock(RIGHT)
    function PANEL:DoClick(x, y)
       self:SetOpen(not self.open)
    function PANEL:SetOpen(o)
       if self.open then
          surface.PlaySound("ui/buttonclickrelease.wav")
          surface.PlaySound("ui/buttonclick.wav")
       self.open = o
       self:PerformLayout()
       self:GetParent():PerformLayout()
       sboard_panel:PerformLayout()
    function PANEL:DoRightClick()
    vgui.Register( "TTTScorePlayerRow", PANEL, "Button" )
Steam ids were xxx'd out for privacy reasons.
What in this code is causing those errors?
Think i found it
capital S in self.cols.................
testing now.
Yes, nvm.. it was the capital S.  How dumb lol
« Last Edit: September 01, 2013, 09:19:06 am by DJ Mikey »
