Author Topic: Issues with Can Target  (Read 4287 times)
Offline MelonDelon
« on: August 27, 2013, 10:26:00 am »
Hello everyone!
I hope someone can help me out here, so far this is my issue:
Moderators can target groups they shouldn't be able to target, and this is how I did the set-up.
Users: http://i.imgur.com/WglQmWX.png
Donators: http://img194.imageshack.us/img194/3093/7oyt.png
Moderators: http://i.imgur.com/5z9qDHk.png
Admins: http://i.imgur.com/Ywhets4.png
Superadmins: http://img841.imageshack.us/img841/7168/f7po.png
Can someone point out where I did my mistake? Cause I managed to fix that mods could target superadmins, now it's mods that can target mods though and vice versa with mod-admin.
Thanks in advance!
Re: Issues with Can Target
« Reply #1 on: August 27, 2013, 02:24:29 pm »
I've looked at all the images, compared it to my own (limited to default) groups, and, can not see a problem.
What commands are they running?
You're saying you want mods to not be able to target other mod group members?
Give us an example of what command groupX member that !%groupY in which groupY inherits groupX can do.
While you're at it, provide us the file output of "ulx debuginfo" from a server console with players connected that are able to do things they shouldn't to others. (it will put a file in your server data/ulx folder.)
Offline MelonDelon
« Reply #2 on: August 28, 2013, 01:04:36 pm »
Thanks for replying JamminR!
Well they can physgun us admins, even after I used a groupallow and restrict it to !%admin too, yet it worked when I used it on the admin-group to !%superadmin, but now we're stuck with mods have the issue I originally made this post for; Admins could lift superadmins while mods couldn't, and shouldn't.
But now mods are like superadmins if not above, cause we did so SA's can't lift one and another on our server. We had this issue in the past but the SA that fixed it is no longer with us, and I'm trying to figure out what's going on here.
Hope this is efficient enough information for you to figure something out JamminR
« Reply #3 on: August 28, 2013, 02:15:13 pm »
Give us the debuginfo as I described, as it will give us much more to work with as I'm now lost as to what all you're trying to do compared to what you (think you?) have allowed and limited.
« Reply #4 on: August 30, 2013, 09:14:36 am »
Yes, giving us the debuginfo.txt file would help us look at all of your configuration so we can see what's up. (contains SteamID's, so feel free to PM or email it to us instead).
One thing to test: Can the groups that can physgun higher-ups target the same higher-ups with different commands such as ulx slap? If they can't, then it seems something is wrong with the physgun permissions itself-- perhaps a different addon/gamemode is interfering with it?
