Author Topic: ULX v3.61 and ULib v2.51 -- Muyaku  (Read 67544 times)
« on: August 30, 2013, 03:37:43 pm »
This one brings the fix you have all been waiting patiently for -- the workaround Garry's file I/O breakages.
Our new releases have been codenamed "Muyaku". So what else has changed in ULib 2.51 and ULX 3.61? XGUI has gained a nice ability to search bans, thanks to our own forum member iSnipeu. Full details can be seen below.
Quote from: ULib changelog
   * [FIX] ULib.ucl.userAllow not working on disconnected players (Thanks, JackYack13).
   * [FIX] Issue with setting groups with capitals in the group name (Thanks, FPtje!).
   * [FIX] Calling SetUserGroup not passing on information to clients (Thanks, Bo98).
   * [FIX] Garry's File I/O bugs by wrapping all his I/O.
   * [FIX] A user group lower casing that no longer belonged in the code (Thanks, iamalexer).
   * [FIX] Some issues with casing in ULib commands (Thanks, TheSpy7).
   * [FIX] Invalid time restrictions throwing an error (Thanks, Scratch).
   * [FIX] A problem with targeting in single player (Effected XGUI. Thanks, bender180).
   * [FIX] A problem with self-target restrictions breaking commands under certain conditions (Thanks, iSnipeu).
   * [FIX] A bug with being able to update replicated variables after running a listen server and then joining another server.
   * [REMOVED] Temp garry-patch for reading from the data directory that appears to be fixed now.
Quote from: ULX changelog
   * [ADD] cl_pickupplayers (defaults to 1) to allow an admin to disable the ability to pickup players (so they don't do it on accident). Done in collaboration with FPtje.
   * [ADD] %curmap% and %steamid% variables in "ulx showMotd" URL for custom-served MOTDs (Thanks Mors-Quaedam).
   * [ADD] XGUI: Bans are now searchable. (Thanks to iSnipeu for the code contribution!)
   * [FIX] "#" (Pound signs) removing content in ulx asay (Thanks bener180).
   * [FIX] Reserved slot mode 3 not kicking the shortest connected player as it is supposed to (Thanks monkstick).
   * [FIX] No longer able to physgun frozen players (Thanks ms333).
   * [FIX] XGUI: Added checks to prevent admins from being able to edit ban information past their restrictions (Thanks Zaph).
   * [FIX] XGUI: Infobar text no longer displaying.
   * [FIX] XGUI: Error caused when closing the fban window after the targeted player has left the server (Thanks nathan736).
   * [FIX] XGUI: Issues with handling min / max number restrictions.
   * [FIX] XGUI: Map icons not loading.
   * [FIX] XGUI: Ban menu bugfixes.
   * [CHANGE] Jail models. The jail is slightly bigger and can't be shot through anymore (Thanks Mors-Quaedam).
   * [CHANGE] Updated PvP damage cvar to reflect Garry's changes (Thanks Mors-Quadam).
   * [CHANGE] "ulx gag" now uses a server-side hook (much more robust).
As always, you can download them at our homepage.
« Last Edit: August 30, 2013, 03:40:08 pm by Megiddo »
Re: ULX v3.61 and ULib v2.51 -- Muyaku
« Reply #1 on: August 31, 2013, 03:28:14 am »
The jail thing is a great fix. It caused an exploit on our TTT server if someone was jailed before.
Thanks a lot!
Offline Vizzy
« Reply #2 on: August 31, 2013, 02:41:38 pm »
works good
15:44:09 Lua Error: [AddCSLuaFile] Couldn't find 'effects/ulx_firework/init.lua' (<nowhere>)
15:44:09 Lua Error: [AddCSLuaFile] Couldn't find 'effects/ulx_fireworkstem/init.lua' (<nowhere>)
sure this is new error though
referencing some missing files
not big deal but ya
« Reply #3 on: August 31, 2013, 05:02:18 pm »
It actually is our fault, JamminR. It won't hurt anything, though.
« Reply #4 on: August 31, 2013, 05:03:28 pm »
I was about to say something, until Megiddo said it.
Inside "ulx\lua", there is an effects folder. Basically the fix for it is to remove the effects folder since it doesn't really include anything.
« Reply #5 on: August 31, 2013, 05:04:32 pm »
Oops.
Sorry.
I WANT FIREWORKS!
« Reply #6 on: August 31, 2013, 05:11:23 pm »
Fireworks would be cool.
3.62 needs it!
Offline aaron
« Reply #7 on: September 01, 2013, 10:19:03 am »
Jail can still be shot through for me.
Running this version on TTT
« Reply #8 on: September 01, 2013, 12:45:38 pm »
Shot through with what weapon?
Offline aaron
« Reply #9 on: September 01, 2013, 02:11:19 pm »
Sorry my mistake. It is not your fault that this wasn't correct :)
« Last Edit: September 01, 2013, 02:21:54 pm by aaron »
« Reply #10 on: September 16, 2013, 09:20:20 am »
Ulysses is still kicking. I love it. Good work guys!
« Reply #11 on: September 16, 2013, 04:49:19 pm »
Yep! Glad to see you're still alive, too! :)
« Reply #12 on: September 20, 2013, 06:06:24 am »
Ha, I poke around from time to time.
Trying to figure out if I have the time to contribute again.
Offline The_Bryce
« Reply #13 on: September 28, 2013, 12:10:08 pm »
When I tried to install the update, it said that there was a Virus in the download.
Threatname: Suspicious.Cloud.9
:-\  Why is it saying this? I have installed this before no problem.
« Reply #14 on: September 28, 2013, 12:32:07 pm »
It's called a "false positive". Where the antivirus software thinks it's harmful, but it's not at all.
I can assure you, that it's clean. As I've used Avast!, AVG and Avira, and never gotten anything about ULX/ULib installer being harmful.
