Author Topic: TTT Kill Revealer  (Read 18063 times)
Offline MrSpencer
TTT Kill Revealer
« on: September 02, 2013, 03:27:07 am »
I seen another Post on this but the download link doesnt work anymore. I need one really badly, that says You where killed by <name> He was Innocent or Traitor Or Detective Someone please help
Offline aaron
Re: TTT Kill Revealer
« Reply #1 on: September 02, 2013, 09:37:22 am »
A simple google search found one.
/index.php/topic,6059.0.html
« Reply #2 on: September 02, 2013, 12:18:59 pm »
Aaron, that link 404'ed.
Thanks for directing him to google though!
MrSpencer, bender's pretty active around these forums.
If you can't find anything working using the search, perhaps reply to that post or another involving any TTT item you're looking for.
« Reply #3 on: September 02, 2013, 12:39:34 pm »
Bender also has his own website, http://www.bendersvilla.net/
And can be found on Steam here. http://steamcommunity.com/profiles/76561198023178705
Offline iSnipeu
« Reply #4 on: September 03, 2013, 02:00:21 am »
Untested, but this should work.
if SERVER then
util.AddNetworkString("WhoKilled")
hook.Add("PlayerDeath", "WhoKilled", function( victim, weapon, killer )
net.Start("WhoKilled")
net.WriteString( (killer:IsPlayer() and killer:Nick() or "the world") )
net.WriteInt( (killer:IsPlayer() and killer:GetRole() or -1), 8 )
net.Send( victim )
end)
net.Receive("WhoKilled", function()
local killer = net.ReadString()
local killer_role = net.ReadInt(8)
local str = "You were killed by "..killer.."!"
if killer_role == ROLE_INNOCENT then
chat.AddText( Color(0,255,0), str )
elseif killer_role == ROLE_TRAITOR then
chat.AddText( Color(255,0,0), str )
elseif killer_role == ROLE_DETECTIVE then
chat.AddText( Color(0,0,255), str )
chat.AddText( Color(255,255,0), str )
end)
« Last Edit: September 05, 2013, 06:07:00 pm by iSnipeu »
Offline MrSpencer
« Reply #5 on: September 03, 2013, 03:02:32 am »
if SERVER then
net.WriteInt( (killer:IsPlayer() and killer:GetRole() or -1) )
net.Send( victim )
end)
local killer_role = net.ReadInt()
end)
Where should i place this?
« Reply #6 on: September 03, 2013, 02:22:35 pm »
Opinion;
As a server admin, even one who will never learn how to code in a game's way of interaction with the game, the admin should learn the basics of where/what/how the server does things on the back end.
I will tell the answer to your question, in great hopes you'll remember it, experiment with answers like it in the future, and, I pray, teach your fellow server want-to-be-better hosts where pieces of code, for, at least in this respect, Gmod, go.
Fact:
Shut down server.
You copy the code.
Open up notepad.
Paste the code.
Save it to <your Gmod server path>\lua\autorun\anyfilename_perhaps_tttkillreveal.lua
You'll need to figure out how to save in .lua and not .txt on your own.
Offline MrSpencer
« Reply #7 on: September 05, 2013, 12:11:47 am »
Well It didn't work. Bad luck i guess
Offline sabo
  • Hello :)
    • The Elite Gaming
« Reply #8 on: September 05, 2013, 07:20:52 am »
Hey, this is what I use, I thought I could share it with you :)
Put this into lua/autorun/server/killmsg.lua
AddCSLuaFile("autorun/client/cl_killmsg.lua")
print("Kill message script loaded!, continuing happily!")
function PrintKillMsgOnDeath(victim, wep, attacker)
if GetRoundState() == ROUND_ACTIVE then
if (attacker:IsPlayer()) and (attacker ~= victim) and attacker:IsTraitor() then
umsg.Start("KillMsg", victim)
umsg.String(attacker:Nick())
umsg.Char(2)
umsg.End()
if (attacker:IsPlayer()) and (attacker ~= victim) and attacker:IsDetective() then
umsg.Char(3)
umsg.End()
if (attacker:IsPlayer()) and (attacker ~= victim) and !attacker:IsDetective() and !attacker:IsTraitor() then
umsg.Char(1)
umsg.End()
hook.Add("PlayerDeath", "ChatKillMsg", PrintKillMsgOnDeath)
And put this into lua/autorun/client/cl_killmsg.lua
print("Kill message script loaded!")
local teamslist = {" innocent.", " traitor.", " detective."}
local teamscolors = {Color(0, 200, 0, 255), Color(180, 50, 40, 255), Color(50, 60, 180, 255)}
function PrintKillMsg(um)
local nick = um:ReadString()
local team = um:ReadChar()
chat.AddText(Color(255, 255, 255), "You were killed by ", teamscolors[team], nick, Color(255, 255, 255), ", he was a", teamscolors[team], teamslist[team])
usermessage.Hook("KillMsg", PrintKillMsg)
Hope this helps ;)
Good luck.
Offline MrSpencer
« Reply #9 on: September 05, 2013, 03:42:42 pm »
My players are getting a client error: I looked through the file and didn't see and ) out of place?
[Sir Noname|37|STEAM_0:1:63862704] Lua Error:
[ERROR] lua/autorun/client/cl_killmsg.lua:3: ')' expected near '3'
1. unknown - lua/autorun/client/cl_killmsg.lua:0
Offline iSnipeu
« Reply #10 on: September 05, 2013, 06:04:23 pm »
What error did you get?
EDIT: Oh I forgot to include the bit count, try it again now (put into lua/autorun)
« Last Edit: September 05, 2013, 06:08:00 pm by iSnipeu »
Offline sabo
  • Hello :)
    • The Elite Gaming
« Reply #11 on: September 07, 2013, 04:31:36 pm »
You should consider setting up your server again.
Looks like an addon you have added is conflicting it because I am using the exact code I gave you on my server and I never had that problem.
