Author Topic: UTeam - Set teams based on usergroup.  (Read 447535 times)
Re: UTeam - Set teams based on usergroup.
« Reply #105 on: May 16, 2008, 05:15:25 pm »
How do you know it's not working? There's no normal indication of groups with a normal setup.
Offline Alex
« Reply #106 on: May 16, 2008, 05:23:11 pm »
It's not working because It doesn't do the right things, like on the admin team I put the model "police" well all the admin skins are what they choose. Another example is I set that superadmins get 1000 HP 1000 Armor, well guess what It doesn't happen the HP is 100 and Armor is 0. NOW do you get it? BTW I don't mean to sound mad or anything in this post it's just my way of writing.
:) Alex T. :)
« Reply #107 on: May 16, 2008, 05:25:32 pm »
You left a quote off of
                       "name"          "Moterators
Also, You may have meant 'moderator'
« Last Edit: May 16, 2008, 05:27:47 pm by JamminR »
Offline Alex
« Reply #108 on: May 16, 2008, 06:49:29 pm »
THANK YOU SOOOOO MUCH!! ;D This solved my problem! What can I do to repay you? Infact do you want admin on my server? I would be happy to give it to you. :)
Again thank you so much.
:) Alex T. :)
Offline spbogie
« Reply #109 on: May 16, 2008, 06:53:36 pm »
You don't have a closing " on the name of your new group. I can't say how many times I've seen this error throughout our forums.
People, please double check your config files before posting about problems.
« Reply #110 on: May 16, 2008, 07:04:44 pm »
Welcome, and no thanks to admin.
If you feel like giving something, become a donator (single or subscriber). (Not obligated, only if you wish)
Offline Smoot178
« Reply #111 on: August 19, 2008, 02:41:27 pm »
Any ideas why this won't work for the new spacebuild 3?
http://fileshack.us/get_file.php?id=271153&file=tmpMNlFi.jpg
« Reply #112 on: August 19, 2008, 07:32:50 pm »
Smoot, attach the actual text file IF the following doesn't work. Use the 'additional options' link below post.
As for few ideas;
What isn't working? Get any errors at server startup, or player join, on either server console or players?
1) You have the same gamemode listed several times. I wouldn't think that would confiuse the script, but it's a possibility.
I believe spbogie changed his code so that case sensitivity doesn't matter (Sandbox is same as sandbox)
2) What is the _real_ name of the gamemode according to the server? Do you have that in the list?
I don't remember the console variable to check that. Sorry. sv_gamemode or gamemode.
Heck, from server console, type "find gamemode" and it will surely show.
Offline Smoot178
« Reply #113 on: August 20, 2008, 10:41:45 am »
It works now.  Apparently the name was reallllyyy long, but someone over at the SB3 forum helped me.
Thanks anyways :)
Offline Burlak01
« Reply #114 on: August 27, 2008, 05:00:38 pm »
What did you type in for the new SpaceBuild 3 gamemode?
Offline Sylar
« Reply #115 on: September 01, 2008, 12:19:39 am »
??... When this addon is enabled, the voice communication is blocked by it :-[
« Reply #116 on: September 01, 2008, 12:39:33 am »
No it's not. Just enable alltalk.
Offline Sylar
« Reply #117 on: September 01, 2008, 12:43:15 am »
wow sorry
Gareth_25
« Reply #118 on: September 05, 2008, 03:22:16 am »
As nobody seems to have answered :
The gamemode name in Uteam should be :  "Spacebuild 3: The New Age (Beta)"
Offline Aqua92
« Reply #119 on: September 17, 2008, 08:24:42 am »
love this addon but i need help... i added with "ulx addgroup "member"" the group member... now i tried to configure with uteam. thats what i typed in
      "6"
         "name"      "Mechanicfuse.com Member"
         "group"      "member"
         "colour"
            "a"      "255"
            "B"      "0"
            "g"      "255"
            "r"      "0"
         "hp"      "150"
         "armor"      "0"
did i something wrong? caus the guys i added has no title... he is not unassigned he is not guest he is not whatever
/EDIT: found my mistake^^ i wrote "colour" instead of "color"
sry for post
