Author Topic: UTeam - Set teams based on usergroup.  (Read 447535 times)
Offline jjb123
Re: UTeam - Set teams based on usergroup.
« Reply #15 on: March 17, 2007, 10:51:20 am »
That did the trick, thank you. ;D
Offline VincentAvery
« Reply #16 on: March 21, 2007, 09:16:09 am »
I'm having a problem as well... I'm using ULX, sui_scoreboard, and uteam... and the scoreboard shows everyone as team "Unassigned"
I get this when starting the server:
ERROR: Hook 'UTeamSetupTeams' Failed: includes/modules/hook.lua:43: attempt to index field '?' (a nil value)
Removing Hook 'UTeamSetupTeams'
Adding Player
ERROR: Hook 'UTeamSetTeam' Failed: includes/modules/hook.lua:43: attempt to index field '?' (a nil value)
Removing Hook 'UTeamSetTeam'
here is my uteam.txt file:
"Out"
"teams"
"1"
"name" "SuperAdmins"
"group" "superadmin"
"color"
"a" "255"
"B" "85"
"g" "200"
"r" "0"
"2"
"name" "Admins"
"group" "admin"
"color"
"a" "255"
"B" "50"
"g" "50"
"r" "255"
"3"
"name" "Players"
"group" "user"
"color"
"a" "255"
"B" "255"
"g" "100"
"r" "0"
"gamemodes"
"1" "spacebuild"
Offline jjb123
« Reply #17 on: March 21, 2007, 11:53:16 am »
are you sure spacebuild is the name of the gamemode your playing in? IF you dont play in the gamemodes listed in the file by you you will get unassigned people.
« Reply #18 on: March 21, 2007, 12:20:19 pm »
It doesn't work in other gamemodes, this is something I've noticed as well.
« Reply #19 on: March 21, 2007, 08:43:22 pm »
Oh, really? Is there any way around that? Or do you know what causes it? What gamemode does it work in? the spacebuild gamemode is derrived from sandbox, i don't know if that makes a difference or not... I'd really like to get this working. Any ideas?
Offline spbogie
« Reply #20 on: March 25, 2007, 08:51:10 am »
It works in other gamemodes, it just uses the gamemodes name rather than the value of sv_gamemode (because sv_gamemode could change without the gamemode changing). Use the name that shows up on the scoreboard, it is case-sensitive. (for spacebuild it's "SpaceBuild")
Offline spbogie
« Reply #21 on: March 25, 2007, 07:12:09 pm »
New Version Released
ChangeLog:
  • Version 1.1
    +Added support for setting variables on the player table (ie. SprintSpeed)
    *Fixed errors when running on gamemodes not in list
    *Gamemodes are based off name in scoreboare, but are no longer case-sensitive
The Soup
« Reply #22 on: April 09, 2007, 12:27:43 pm »
No one else can hear my Mic after this, but I can't figure out the alltalk variable.
Name is temporary, still waiting for my confirmation EMail.
Kingtendo
« Reply #23 on: April 12, 2007, 06:45:02 am »
In The plytable can you set things like prop limits to each user group. i want to be able to do this but i do not know how
The Soup
« Reply #24 on: April 12, 2007, 01:13:24 pm »
Doesn't load?
I get Console error:
LS: -- Error running file ------------------------------------
LS: - File: autorun/server/UTeam.lua
LS: - autorun/server/UTeam.lua:21: table index is nil
LS: ----------------------------------------------------------
Help?
« Reply #25 on: April 12, 2007, 06:17:13 pm »
Doesn't load?
Help?ntax
Looks like you've edited Uteam.txt , and didn't edit it correctly. (Syntax error, etc)
The Soup
« Reply #26 on: April 19, 2007, 05:56:49 pm »
You see, the problem is that, I didn't change anything since it last worked. Cept for copying it around a couple places. I'll go double check it.
The Soup
« Reply #27 on: April 19, 2007, 05:59:59 pm »
"Out"
"teams"
"1"
"name" "Admins"
"armor" "1000"
"hp" "200"
"color"
"a" "255"
"B" "85"
"g" "200"
"r" "0"
"plytable"
"1" "SprintSpeed:1500"
"2" "WalkSpeed:1000"
"model" "breen"
"2"
"name" "Admins"
"group" "admin"
"armor" "500"
"hp" "150"
"color"
"a" "255"
"B" "50"
"g" "50"
"r" "255"
"plytable"
"1" "SprintSpeed:1000"
"2" "WalkSpeed:500"
"model" "prison"
"3"
"name" "Admins"
"group" "operator"
"armor" "200"
"hp" "100"
"color"
"a" "255"
"B" "0"
"g" "200"
"r" "255"
"model" "police"
"4"
"name" "Players"
"group" "user"
"color"
"a" "255"
"B" "255"
"g" "100"
"r" "0"
"model" "male1"
"gamemodes"
"1" "Sandbox"
That's my UTeam.txt file. In the data folder.
The Soup
« Reply #28 on: April 24, 2007, 07:46:43 pm »
Anyone have an suggestions or ideas as to what I should do?
Offline spbogie
« Reply #29 on: April 26, 2007, 11:44:06 pm »
In the admins team definition you have 2 }'s after player table.
