Author Topic: XGUI Still working with ULX (TTT)?  (Read 15398 times)
Offline SupremeHumanBeing
« on: September 06, 2013, 09:08:43 am »
Hi guys!
New to TTT, really liked the game mode but not happy with the RDM fest so just wanted to get my own little 8 slots server and make sure I can continue to enjoy the game.
I got ULX working as it was easy to just copy paste the data over to the addons folder, but lack of a proper "setup" guide is now giving me headaches.
Where exactly do I change all the settings with the cvars? Not sure where they're supposed to go?
Then my actual question, does XGUI work with the latest build of ULX and ULIB?
I copied XGUI-Master to my addons folder but it destroyed my server with too many lua errors and dropped my frame rate from 300 to 30.
Any help is greatly appreciated.
Re: XGUI Still working with ULX (TTT)?
« Reply #1 on: September 06, 2013, 11:00:09 am »
XGUI is included with ULX, so the only thing you should need to install are the ULib + ULX folders and put them inside addons.
« Reply #2 on: September 06, 2013, 11:07:37 am »
Thanks for the info Decicus.
Can you tell me how to add myself as an admin and where to add the cvars? I am unsure which file I should edit because I can't find a detailed document that explains this to idiots like me
« Reply #3 on: September 06, 2013, 11:39:05 am »
I assume you mean server settings like setting gamemode, hostname etc. Then that's inside server.cfg. Just make a file in Notepad (I recommend using Notepad++), then save as "server.cfg" and place it inside -Garry's Mod server directory-/cfg.
If you have console access, just go on the server, alt-tab and type in the console "ulx adduser yourname superadmin". Replace "yourname" with your name (obviously), a partial of your name works.
You can also try this, by finding your Steam ID: /index.php/topic,5767.0.html
Then do "ulx adduserid YourSteamID superadmin", replace "YourSteamID" with your Steam ID (should be self-explanatory). Both of these commands (you only need to use one of them) will give you full ULX access. Highest rank of Garry's Mod admin, basically.
If you really feel like adding yourself manually, look into the "users.txt" file which is located here: -Garry's Mod server directory-/data/ulib/.
« Reply #4 on: September 06, 2013, 11:57:23 am »
Many thanks!
Ok, I tried the "ulx adduser yourname superadmin". When I open the menu (!menu), I only have basic options there. Screenie in a few seconds
EDIT: Figured it out. No spaces allowed in username.
Ok, its working now! Thanks so much! You've been a great help!
« Last Edit: September 06, 2013, 12:03:25 pm by SupremeHumanBeing »
« Reply #5 on: September 06, 2013, 12:19:55 pm »
One more thing:
How do I get rid of all the NON-TTT maps as listed below?
They're not in the maps folder (currently searching the folders via FTP, might take some time)
http://i.imgur.com/MFwhZB0.png
AND:
Is there a file (like server.cfg) where I can add values to cvars to change the way ULX behaves on the server? Like server messages, autokick rules etc?
« Last Edit: September 06, 2013, 12:25:50 pm by SupremeHumanBeing »
« Reply #6 on: September 06, 2013, 12:45:52 pm »
Those maps are CSS + TF2 maps. They are loaded by default on the server since you probably have TF2 + CSS content mounted. You should check your votemap section of XGUI/ULX to make sure those aren't included there.
About those cvars, if you look into the -GMod server directory-/data/ folder, you will see ulib and ulx, look into those and you should see some .txt files to help you with some settings.
I'm also pretty sure you can check the XGUI (again) for most of those settings. And that will probably be better.
« Reply #7 on: September 06, 2013, 12:47:49 pm »
Thanks again!
I did find some settings in the UI, but there's quite a few that arent there. Like end of round voting and so on. I'll mess around with the settings. Many tahnks again for your help!
« Reply #8 on: September 06, 2013, 12:54:18 pm »
End of round voting isn't in ULX, that must be a plugin/module/addon that you would have to find yourself. I assume Google will help a lot when it comes to that.
« Reply #9 on: September 06, 2013, 12:55:06 pm »
Fantastic!
Thanks again!
« Reply #10 on: September 06, 2013, 12:55:53 pm »
Indeed, XGUI is now integrated into ULX. No need to do additional downloads or checkouts.
By default, your server (and ULX) will include maps that are included with other mounted gamemode packages, these may not be part of the servers map folder, but included with Steam packages.
Though you can edit out maps shown to the 'votemap' command, I'm not so sure we include a way to show maps only for one gamemode for those with "ulx map" access like your example.
We're Ulysses, we try to admin everything, not just one gamemode. :)
As for various ULX settings, XGUI controls all the settings we offer in text files.
That being said, if you like text like I do, first check out your server/data/ulx folder for config.txt, and several other *.txt files.
Additionally, if not in your server/data/ulx folder you may copy some other special *.txt setting files from /gmod/addons/ulx/data/ulx/ to your gmod/data/ulx folder, then edit there.
Last but not least, please, before asking any further questions, make sure they've not been answered in our FAQ section.
Frequently Asked Questions
(I know at least one so far has been answered there, which Decicus was nice enough to type out instead of referencing our FAQ)
« Reply #11 on: September 06, 2013, 01:15:43 pm »
Alright, alright. I'll stop being nice next time... :P
« Reply #12 on: September 06, 2013, 01:53:16 pm »
You could always be nice and direct them to the FAQs for questions already answered :P
After 5+ years here, you'll understand...typing out how to add oneself, get's quite tiring.
Hence why 'having trouble with access?' is one of our most viewed topics. :)
Which reminds me, Megiddo or Stickly Man need to update the player groups link in ulx_readme.txt to match step 2 of that FAQ. :)
« Reply #13 on: September 06, 2013, 03:45:28 pm »
Thanks, done.
