Author Topic: Adding a "string.sanitize" function.  (Read 5628 times)
« on: October 08, 2013, 03:06:17 pm »
I think a function that would remove "dangerous" characters from a string may be needed, it would help with things such as integration with SQL.
  1. function string.sanitise( str )
  2.         return string.Trim(string.Replace(string.Replace(string.Replace( tostring(str), "\\", "/" ), "\"", ""), ";", ""))
  3. end
I felt that a function like the one above was always missing from Garrysmod, and I am sure that we had problems because of it.
I hope that if a function like the one above is added to ULX, that it would help many developers in the long run.
Re: Adding a "string.sanitize" function.
« Reply #1 on: October 08, 2013, 06:21:31 pm »
This is the job of the individual SQL library, as escape methods differ. Just like the one GMod includes.
