Author Topic: UnoLimited - Change spawn limits per user group  (Read 60702 times)
Offline nexbr
Re: UnoLimited -- Change Spawn Limits per User Group.
« Reply #15 on: October 19, 2013, 08:23:26 am »
Great work.
Thanks for bringing this to the modern Ulib and Gmod era.
OK, I'm glad you liked.
Offline xLiaMz
« Reply #16 on: November 04, 2013, 11:41:55 am »
Doesn't work for 2.5. DarkRP? I've set Admin's etc to have more props, however they dont? I have 60 default on the server and when I put Administrator to have 2.0 they dont have 120? When I put SuperAdmin's to Unlimited they can only have 60.
« Reply #17 on: November 04, 2013, 12:09:18 pm »
Liam, years ago during my role in UnoLimited, I found that DarkRP uses some of the exact same functions to limit banned props and other limits as UnoLimited does.
It was a conflict that couldn't be helped, other than to not try to use both.
It's likely the DarkRP code hasn't changed, and you'd need to most likely ask the DarkRP authors to write in the same 'group limit' functions as UnoLimited does.
Reference old thread discussion history @ /index.php/topic,3864.45.html#msg17257 />Nexbr may of course dig deeper and verify, but that would be my guess.
Offline nexbr
« Reply #18 on: November 04, 2013, 12:51:20 pm »
Try change to Max Value Multiplier, but i think is that DarkRP is OverWriting these Hooks.
Offline xLiaMz
« Reply #19 on: November 04, 2013, 02:24:40 pm »
So I have to ask the creators, That's going to be a mission. :S
Thanks for the reply anyway :)
I don't understand?
Thanks for the reply. :)
Offline nexbr
« Reply #20 on: November 04, 2013, 02:28:16 pm »
Try Move the Limit Slider to Maximum value.
But i think the problem is DarkRP, It are Overwriting the UnoLimited Limits Manager.
Offline nexbr
« Reply #21 on: November 04, 2013, 04:19:20 pm »
I think i know a way to Overwrite DarkRP or any other Gamemode, i'll update the Addon in the next days.
« Reply #22 on: November 04, 2013, 07:06:41 pm »
I don't understand?
He's saying try setting a different setting, but, he believes DarkRP uses the same Gmod hooks that UNoLimited does.
The same answer as me but with an additional step.
Be careful..though you could set a ULib hook priority value, you might break what other mods, including DarkRP, are using to do.
I think DarkRP uses the hooks for prop banning. (I've not looked at the DarkRP code in years to know)
Offline xLiaMz
« Reply #23 on: November 05, 2013, 08:26:34 am »
This would be good if you can do it, thanks.
EDIT- This was my response when asking him (https://github.com/FPtje/DarkRP/issues/1149)
« Last Edit: November 05, 2013, 08:34:46 am by xLiaMz »
Offline nexbr
« Reply #24 on: November 05, 2013, 11:43:11 am »
I just tested UnoLimited on DarkRP.
it is working Fine.
Try update your DarkRP.
And check if you have any other addon that can restrict Props limits.
« Last Edit: November 05, 2013, 11:44:47 am by nexbr »
Offline xLiaMz
« Reply #25 on: November 06, 2013, 08:16:51 am »
I'm using DarkRP 2.5 and im 100% sure its not working for me, Ill test it again soon and give you the results.
EDIT - Working now, I don't know what I did but i believe it is (I tried this with max props set to one, hope it works when its 60)
« Last Edit: November 08, 2013, 03:02:44 am by xLiaMz »
Offline xLiaMz
« Reply #26 on: November 09, 2013, 06:39:51 pm »
The limit doesn't count when trying to stack things, idk if you could edit this or if its stacker's fault anyway thought I'd let you know.
Offline xLiaMz
« Reply #27 on: November 20, 2013, 12:09:13 pm »
Last post - "The limit doesn't count when trying to stack things, idk if you could edit this or if its stacker's fault anyway thought I'd let you know."
Also, would this have something to do with certain ranks not been able to spawn in any props?
« Reply #28 on: November 20, 2013, 03:14:30 pm »
Liam, It works for nexbr and I in Sandbox.
It works for nexbr in his quick test of DarkRP.
It's likely you have another addon that's conflicting in someway.
If there's another mod that overwrites the same garry's functions UnoLimited uses, then no, there's no way nexbr (or I) can edit to fix.
It's up to you to determine those answers, and the DarkRP author is apparently not going to help you by adding group limits.
Offline nex86
« Reply #29 on: March 14, 2015, 02:44:34 pm »
it does not pop up in xgui and neither in the permissions.
I have it installed correctly like the other mods. what is the problem here?
