Author Topic: Restrict workshop dupes  (Read 10191 times)
Offline //AG// Not Me
« on: October 18, 2013, 04:14:26 pm »
Hello, I was wondering how i would go about restricting workshop dupes, but letting people spawn in there own dupes. thanks
Re: Restrict workshop dupes
« Reply #1 on: October 18, 2013, 06:04:40 pm »
Replace your:
gamemodes\sandbox\gamemode\spawnmenu\creationmenu\content\contenttypes\dupes.lua with this:
  1.
  2. local HTML                              = nil
  3. local DupeInClipboard   = false;
  4.
  5. spawnmenu.AddCreationTab( "#spawnmenu.category.dupes", function()
  6.
  7.         HTML = vgui.Create( "DHTML" );
  8.                 JS_Language( HTML )
  9.                 HTML:SetAllowLua( true );
  10.                 HTML:OpenURL( "asset://garrysmod/html/dupes.html" );
  11.                 HTML:Call( "SetDupeSaveState( " .. tostring( DupeInClipboard ).. " );" );
  12.
  13.         ws_dupe = WorkshopFileBase( "dupe", { "dupe" } )
  14.         ws_dupe.HTML = HTML
  15.
  16.         function ws_dupe:FetchLocal( offset, perpage )
  17.
  18.                 local f = file.Find( "dupes/*.dupe", "MOD", "datedesc" )
  19.
  20.                 local saves = {}
  21.
  22.                 for k, v in pairs( f ) do
  23.
  24.                         if ( k <= offset ) then continue end
  25.                         if ( k > offset + perpage ) then break end
  26.
  27.                         local entry =
  28.                         {
  29.                                 file    = "dupes/" .. v,
  30.                                 name    = v:StripExtension(),
  31.                                 preview = "dupes/" .. v:StripExtension() .. ".jpg"
  32.                         }
  33.
  34.                         table.insert( saves, entry );
  35.
  36.                 end
  37.
  38.                 local results =
  39.                 {
  40.                         totalresults    = #f,
  41.                         results                 = saves
  42.                 }
  43.
  44.                 local json = util.TableToJSON( results, false );
  45.                 HTML:Call( "dupe.ReceiveLocal( "..json.." )" );
  46.
  47.         end
  48.
  49.         function ws_dupe:Arm( filename )
  50.
  51.                 RunConsoleCommand( "dupe_arm", filename );
  52.
  53.         end
  54.
  55.         function ws_dupe:DownloadAndArm( id )
  56.
  57.                 chat.AddText( Color(200,50,50), "Disabled Feature", Color(200,200,200), ": You are not allowed to spawn workshop dupes here." )
  58.                 --[[MsgN( "Downloading Dupe...\n" )
  59.                 steamworks.Download( id, true, function( name )
  60.
  61.                         MsgN( "Finished - arming!\n" )
  62.                         ws_dupe:Arm( name );
  63.
  64.                 end )]]
  65.
  66.         end
  67.
  68.         function ws_dupe:Publish( filename, imagename )
  69.
  70.                 RunConsoleCommand( "dupe_publish", filename, imagename )
  71.
  72.         end
  73.
  74.         return HTML
  75.
  76. end, "icon16/control_repeat_blue.png", 200 )
  77.
  78.
  79. hook.Add( "DupeSaveAvailable", "UpdateDupeSpawnmenuAvailable", function()
  80.
  81.         DupeInClipboard = true;
  82.
  83.         if ( !HTML ) then return end
  84.
  85.         HTML:Call( "SetDupeSaveState( true );" );
  86.
  87. end )
  88.
  89. hook.Add( "DupeSaveUnavailable", "UpdateDupeSpawnmenuUnavailable", function()
  90.
  91.         DupeInClipboard = false;
  92.
  93.         if ( !HTML ) then return end
  94.
  95.         HTML:Call( "SetDupeSaveState( false );" );
  96.
  97. end )
  98.
  99. hook.Add( "DupeSaved", "DuplicationSavedSpawnMenu", function()
  100.
  101.         if ( !HTML ) then return end
  102.
  103.         HTML:Call( "ShowLocalDupes();" );
  104.
  105. end )
  106.
  107.
  108. concommand.Add( "dupe_show", function()
  109.
  110.         g_SpawnMenu:OpenCreationMenuTab( "#spawnmenu.category.dupes" );
  111.
  112.         timer.Simple( 1.0, function() if ( !IsValid( HTML ) ) then return end HTML:Call( "ShowLocalDupes();" ); end )
  113.
  114. end, nil, "", { FCVAR_DONTRECORD } )
  115.
