Author Topic: [TTT] [ADDON] How to undo a ulx slaynr command  (Read 24595 times)
Offline Dyrone
« on: November 02, 2013, 11:01:30 pm »
Hello, I am using the TTT ULX Addon by Bender180 and Skillz
http://steamcommunity.com/sharedfiles/filedetails/?id=127865722&searchtext=ttt+commands
I am wondering if there is any way to cancel a "ulx slaynr" command that has been placed on someone.
I have already tried !slaynr [name] 0 which does not seem to work.
Any suggestions would be appreciated.
Re: [TTT] [ADDON] How to undo a ulx slaynr command
« Reply #1 on: November 03, 2013, 03:55:48 am »
"ulx rslaynr Name"
Remove SlayNR, basically.
Offline Dyrone
« Reply #2 on: November 03, 2013, 04:13:55 am »
Thanks  ;)
929 slay's removed on me, do not ask.
« Reply #3 on: November 03, 2013, 05:33:11 am »
Thanks for helping decicus. I've just looked over the release thread here for TTT commands, and didn't know rslaynr existed myself.
LOL.
And, welcome to our community. Feel free to look around, and check out our releases section.
You may find other releases or ideas you like.
« Reply #4 on: November 03, 2013, 06:26:15 am »
No problem.
It isn't really documented, I might write up a little page about opposites that I can request Bender or something to add to the thread.
Offline sabo
  • Hello :)
    • The Elite Gaming
« Reply #5 on: November 03, 2013, 07:43:58 am »
There are 2 options hooked up with slaynr:
How can you miss that? What could the 2nd option possibly do? RenewSlaynr, RedoSlaynr, RideahorseSlaynr or RamboSlaynr?
-The proof is in the pudding.
« Reply #6 on: November 03, 2013, 09:26:01 am »
Keep in mind you're using the ULX menu. I'm used to using commands from my console/chat, others might be used to that too.
« Last Edit: November 03, 2013, 10:24:39 am by Decicus »
Offline bender180
    • Benders Villa
« Reply #7 on: November 03, 2013, 09:46:08 am »
hmm thought i put that in the post ill have a look and make sure everything is there.
« Reply #8 on: November 03, 2013, 02:33:35 pm »
Thanks Bender. Also, I've not looked at your code, is there a 'help' variable in your command set ups?
If so;
All, "ulx help" should show those commands in console if you have access to them.
Offline bender180
    • Benders Villa
« Reply #9 on: November 03, 2013, 06:27:53 pm »
If so;
 all the commands i worked on have the ulx help variable the ones skillz worked of im not 100% sure but id think he'd have included them.
EDIT: Double checked all commands have help but opposites are not explained in them.
« Last Edit: November 03, 2013, 06:29:54 pm by bender180 »
« Reply #10 on: November 03, 2013, 10:56:24 pm »
That was mostly my main concern, the opposites aren't really that easy to use unless you go into the ULX menu or just accidently type them in.
« Reply #11 on: November 04, 2013, 05:32:55 pm »
I thought we listed opposites directly in the command? Can you paste the ulx help output, Bender?
Offline bender180
    • Benders Villa
« Reply #12 on: November 04, 2013, 06:20:31 pm »
im not sure what your asking megiddo... :/
« Reply #13 on: November 04, 2013, 07:12:25 pm »
Megiddo is saying, if opposites are set up properly within the addparam object setup, and a help param is included, we also have the 'ulx help' display the 'opposite' command.
Could you or someone please display the output of a 'ulx help' portion from the console that these commands display.
Offline bender180
    • Benders Villa
« Reply #14 on: November 04, 2013, 07:17:53 pm »
ah i see, here you go
  1. Category: TTT Admin
  2.         o ulx force <players> <Role> - Force <target(s)> to become a specified role. (say: !force) (opposite: ulx sforce)
  3.         o ulx forcenr <players> <Next Round> - Forces the target to be a detective/traitor in the following round. (say: !nr)
  4.         o ulx fspec <players> - Forces the <target(s)> to/from spectator. (say: !fspec) (opposite: ulx unspec)
  5.         o ulx karma <players> [<Karma: 0<=x<=10000, default 1000>] - Changes the <target(s)> Karma. (say: !karma)
  6.         o ulx respawn <players> - Respawns <target(s)>. (say: !respawn) (opposite: ulx srespawn)
  7.         o ulx respawntp <player> - Respawns <target> to a specific location. (say: !respawntp) (opposite: ulx srespawntp)
  8.         o ulx slaynr <player> [<rounds: default 1>] - Slays target(s) for a number of rounds (say: !slaynr) (opposite: ulx rslaynr)
  9.
  10. Category: TTT Utility
  11.         o ulx minply [<minply: default 2>] - Sets the minimum number of players.
  12.         o ulx prevwin - Toggles the prevention of winning. (opposite: ulx allowwin)
  13.         o ulx roundrestart - Restarts the round.
  14.
  15.
  16. Category: TTT Fun
  17.         o ulx credits <players> <Credits> - Gives the <target(s)> credits. (say: !credits) (opposite: ulx silent credits)
  18.         o ulx proptime [<Prop recharge time: 0<=x<=10000, default 1>] - Changes the Prop Recharge Time.
  19.
  20.
  21. C
  22.
