Assumption fail?
Topic: Assumption fail? (Read 7906 times)
talmera
Assumption fail?
November 03, 2013, 09:11:58 am »
Hi, I have recenty set up some new servers and did a fresh install of ulx/ulib and in my console (SRCD) I get this error when trying to complete a ulx command:
Code:
[Select]
[ERROR] Assumption fail!
1. unknown - [C]:-1
I tried searching through the forums but only found one thread on the topic which did not fix my problem :/ does anyone know any way to fix it?
Extra details:
Gamemode: TTT
Dedicated server
Latest SVN
Last Edit: November 03, 2013, 09:26:07 am by talmera
It's not a sin if it can't make me cry
He's not the devil unless there's fire in his eyes
It ain't the ghost if it don't speak in tongue
It's not a victory 'till the battles been won
Megiddo
Ulysses Team Member
Project Lead
Re: Assumption fail?
November 04, 2013, 05:22:17 pm »
There should be a larger stack trace than that, right? Give me more details on your server. Is this a true dedicated server downloaded from steamcmd?
talmera
Reply #2 on:
November 04, 2013, 07:51:02 pm »
yes I downloaded the files for running the server through SteamCMD, oddly enough that is all the error produces there is no stack trace past that, I even set up the -condebug to try and see if that gave more and I got nothing.
Last Edit: November 04, 2013, 08:05:43 pm by talmera
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
November 04, 2013, 08:11:28 pm »
Interesting. We will have to investigate further.
talmera
Reply #4 on:
November 04, 2013, 09:29:38 pm »
just to double check i did another fresh install of ulx/ulib and it does persist, and to clarify auto complete for ulx works fine from within the server but if I attempt it from the gui console for SRCDS then it generates the error.
Megiddo
Ulysses Team Member
Project Lead
Reply #5 on:
November 05, 2013, 05:15:50 am »
To expand on why: autocomplete never used to be possible from srcds, even the gui version. So I stubbed that functionality out.
talmera
Reply #6 on:
November 05, 2013, 06:40:48 am »
ah interesting, is there any way to suppress the error then, I don't mind if it doesn't autocomplete but it produces the error twice for every button I press after "ulx" has been entered in the command box.
Megiddo
Ulysses Team Member
Project Lead
Reply #7 on:
November 05, 2013, 05:01:59 pm »
Find the two places in lua/ulib/shared/commands.lua that 'return error( "Assumption fail!" )' and change it to just be 'return'
Assumption fail?
