Author Topic: 24/7 Minecraft  (Read 6301 times)
Offline Technye
24/7 Minecraft
« on: November 17, 2013, 03:21:21 am »
Hey guys, first of all I got my motd working, so thanks to those who helped me!
I now have another problem, I want to change the server of mine to a 24/7 Minecraft one, the map vote system I used before is removed, I made a file called ttt_mapcycle and merely added ttt_minecraft_b5, and since I wasn't really sure where to put this file, I put it in the garrysmod folder itself, the data/ulx and the data/ulib folder AND into the data folder itself! Now I joined my server and tried it out however once the map was over, the server changed to cs_italy....that's a problem I used to have in the past and I can't remember how I fixed it....anybody mind helping me around? :(
Thanks in advance!
Re: 24/7 Minecraft
« Reply #1 on: November 17, 2013, 06:12:57 am »
First of all, the mapcycle is usually just called "mapcycle.txt". It should go into the <Garry's Mod Server directory>, but it can also go into <Root>\cfg.
You can also add "mapcyclefile mapcycle.txt" into the server.cfg to make sure that it chooses the mapcycle.txt file.
