Author Topic: Silent kick/ban  (Read 6597 times)
Silent kick/ban
« on: November 22, 2013, 02:03:10 pm »
Hello.
Lately I've been developing a few silent commands, mainly kick and ban.
It actually took me a while, until I realized I could use parts of ULX's code (hope you don't mind that I did that and I was planning to release it as an addon on these forums). Although, the "silent" part didn't really work out for me.
Every time someone gets banned through RCON, it seems to print out "Player disconnected (reason "Kicked by Admin (Banned for 1 minute(s): Reason)")". (This is by using ULib.kickban in the command, like the normal "ulx ban") When I tested this, it printed out to everyone. Sometimes (and only sometimes, not every time, it seems) when I banned myself, it also printed. With and without a reason. When I banned someone else, or they banned me, it didn't print at all.
This only seems to happen when I use the "silent ban" command though, when I tried my "silent kick" it didn't print at all. So I have no clue what's causing it (although, it may be Player.Kick, but since it doesn't do it all the time, I don't know).
My code is here, but it's pretty much just the normal "ulx ban" command:
function ulx.sban( calling_ply, target_ply, minutes, reason )
ULib.kickban( target_ply, minutes, reason, calling_ply )
local time = ""
if minutes == 0 then
time = "permanently"
elseif minutes == 1 then
time = "for 1 minute"
time = "for " .. minutes .. " minutes"
local str = "#A banned #T" .. time
if reason and reason ~= "" then
str = str .. " (#s)"
ulx.fancyLogAdmin( calling_ply, true, str, target_ply, minutes ~= 0 and minutes or reason, reason )
Any clues?
(This was only tested on TTT, but I don't believe it really matters if I test on SandBox either)
Re: Silent kick/ban
« Reply #1 on: November 22, 2013, 03:23:44 pm »
As far as I remember, the players on the server will always be notified of kicks and bans, since the message is coming from Source. I believe you'd need a module to make it truly silent.
Re: Silent kick/ban
« Reply #2 on: November 22, 2013, 03:27:34 pm »
That's actually what I thought, but I was just making sure. Thanks for verifying.
Offline Cobalt
Re: Silent kick/ban
« Reply #3 on: November 22, 2013, 06:37:27 pm »
Bans print to the chat, kicks do not. I tested this and it works for me:
  1. function ulx.sban( calling_ply, target_ply, minutes, reason )
  2.
  3.         if target_ply:IsBot() then
  4.
  5.                 ULib.tsayError( calling_ply, "Cannot ban a bot", true )
  6.
  7.                 return
  8.
  9.         end
  10.
  11.         ULib.ban( target_ply, minutes, reason, calling_ply )
  12.
  13.         target_ply:Kick( "Disconnect: Kicked by " .. calling_ply:Nick() .. "(" .. calling_ply:SteamID() .. ")" .. " " .. "(" .. "Banned for " .. minutes .. " minute(s): " .. reason .. ")." )
  14.
  15.         local time = "for #i minute(s)"
  16.         if minutes == 0 then time = "permanently" end
  17.         local str = "#A banned #T " .. time
  18.         if reason and reason ~= "" then str = str .. " (#s)" end
  19.         ulx.fancyLogAdmin( calling_ply, true, str, target_ply, minutes ~= 0 and minutes or reason, reason )
  20.
  21. end
  22. local sban = ulx.command( "Utility", "ulx sban", ulx.sban, "!sban" )
  23. sban:addParam{ type=ULib.cmds.PlayerArg }
  24. sban:addParam{ type=ULib.cmds.NumArg, hint="minutes, 0 for perma", ULib.cmds.optional, ULib.cmds.allowTimeString, min=0 }
  25. sban:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.optional, ULib.cmds.takeRestOfLine, completes=ulx.common_kick_reasons }
  26. sban:addParam{ type=ULib.cmds.BoolArg, invisible=true }
  27. sban:defaultAccess( ULib.ACCESS_ADMIN )
  28. sban:help( "Bans target silently." )
Re: Silent kick/ban
« Reply #4 on: November 23, 2013, 02:13:59 am »
I'll try this, thanks!
